Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-37P50E connected to computer with HDMI cable
We are trying to project our computer onto our Sharp Aquos TV using an HDMI cable. Cant get the computer (new Gateway laptop with Vista) to see the TV. Tried ALT F4 to transfer the image and tried changing the resolution. The TV was bought in the UK and the Computer in the US.
  • DiannaS Sep 28, 2008
    Thanks for the thought. We just purchased this computer from best buy 2weeks ago as a gaming computer for our son. They said it was compatible and that our son could watch his games on the TV. They sold us the cable. So, I would think this computer should be compatible. How do I check the TV? it is3 years old but it says HDMI on the front and has the HDMI port in the back so this would suggest to me that it has this capability.
  • nospam1441 Mar 16, 2009
    My variation is a Lenova Thinkpad T60, a (S)VGA to HDMI adapter and a Sharp Aquos LC-46D82U purchased over a year ago. The Aquos' user manual says that it "should" work and lists supported resolutions. Resolutions that have been tried without success are listed on pg 17 (PDF) of the manual: 800x600, 1024x768, 1280x1024, etc. Using an DVI to HDMI adapter, I can output from my desktop to the Aquos (at 1920x1080) so I know that the input HDMI port is not hosed on the TV. I am looking to hookup laptops like I would to a monitor. This isn't about optimizing, this is about getting something/anything to display.
    I've tried with two different laptops. The Lenovo's VGA port has been verified with a regular 1280x1024 monitor sucessfully -- there is signal leaving the VGA port.
    The only component that cannot be verified is the VGA-HDMI cable, although it is a new cable (<30 days?), never been used elsewhere. It seems hard to believe that it is the culprit -- pilot error is easier for me to believe, but I'm running out of ideas.
    Does anyone have any thoughts/suggestions?
    Sergeant:
  • 208 Answers
I got the chat , but some how it got disconnected.
But i would like to help you in this aspect.
HDMI stands for High Definition Multimedia Interface, and supports transmission of both audio and video in high fidelity.
First make sure these things,
Both your computer and your TV will need to support HDMI interface.
It's quite a recent thing in PC graphics cards, so you may have to resort to S-Video, DVI or VGA for the video, plus a 3.5mm stereo cable (or the optical TOSLINK equivalent) for the sound.
Let know your comments and i will follow up with the suggestions.
Thanx for using fixya,
Good luck.
Posted on Sep 28, 2008
  • Swaminathan R
    Swaminathan R Sep 28, 2008
    I am giving the steps for connecting the computer to the television screen....
    I have taken Vista into consideration.....
    1. First you need a video cable for making the physically connection.
    Most computers have an S-Video port that can be connected to the
    S-Video input of your TV screen using a very cheap S-Video cable (it’s
    round with 4 or 7 pins).
    For better picture quality, you should connect the computer to the
    TV using standard VGA ports or via the DVI to HDMI cable provided your
    TV supports these ports
    2. Open the "display settings" in your Vista computer and activate
    output to the TV screen. You can either mirror content of your computer
    on the TV or extend the display just like a dual monitor screen.
    3. Pick up your TV remote and switch to "External Inputs" from the
    menu. You will need to change the default "Video 1" to a different
    selection which may be "HDMI 1" or "Video 2" depending on how you have
    made the connection.
    Important: Make sure you connect the cable to the TV before turning
    on the computer as sometimes it may fail to recognize external display.
    You may also need to change the screen resolution of your TV using
    the Display settings in your Control Panel else the picture may appear
    distorted.
    Hope this will hel[p you....
    Good luck...
Sharp aquos lenovo sl410 hdmi cable
I would look for a newer driver from lenovo. Has 8.1 got a fix?
Jan 19, 2014 | Lenovo ThinkPad SL Series SL410 (2842F7U)...
Sharp aquos lc-32le600E connected to PC video is fine, but no audio, any advice? Thank you in advance
Good job---Thank You for letting us know you got it and thanks for using FIXYA.
Mar 15, 2012 | Televison & Video
I have connected a Roku Digital Media Player to Sharp AQUOS TV, I am able to get the video but no audio from TV, Audio cable and all are setup properly. Can anyone suggest me? also i see the same problem...
Use the HDMI cable on the Roku. The reason you don't have audio from the laptop is because the HDMI out on the laptop has no audio on it. You need to use a 3.5 mm audio cable to connect the laptop audio to the TV.
May 26, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Sep 15, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
HDMI connection problem
Your TV doesn't like your laptop I guess.
There should be 2 reset buttons behind your TV.
Press the reset button first.
If that doesn't work, try the system reset button next.
If that doesn't work, you'll have to call 1-800-BE-SHARP to help you with the possible software problem with the TV
Good Luck
Feb 12, 2009 | Sharp Aquos LC-32D40U Television
Lcd to pc
YOU MUST GO INTO YOUR COMPUTER CONTROL PANEL TO SET THE DISPLAY SETTINGS FOR YOUR LCD.
Sep 28, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos 42"
Check the settings in the TV set for HDMI sound on the input of the TV that you are using. Try another HDMI cable. It may be defective.
It is also possible that there is a compatiblity problem for the HDMI sound between the TV and the computer's sound protocol.
Jerry G.
Apr 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
3,471 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
