Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Western DIgital 500 GB litght flashes but not working
My Western Digital 500 GB was working fine, but then when I plugged the power cable in the light will flash quickly (twice a second) and there is no reaction from the computer when I plug the USB cable in. Pushing the button in will not make it stop and go to a steady light. I also tried unplugging, holding the button in for 10 seconds, and connecting the power cable in. I have everything on that book. Please help.
  • tidwellnick Sep 28, 2008
    My light comes on and stays on but my computer will not open drive G. Need help!!!!!!!
I discovered that the wrong power adapter was plugged into the Western Digital My Book which is why it was blinking two times a second and fried it. Plugged in a 24v instead of the 12vThe tech support person at Western Digital ignored the information of the blinking light. I fixed the hard drive issue by removing the cover (no easy task) and installing it as a slave drive on my computer. I am backing up that hard drive using another Western Digital My Book.
I would suggest to anyone who has the problem of frying their Western Digital hard drive to make it a secondary drive on your computer. My item was under warranty, but all they would have done is replace the product and not recovered the data. They gave me references on whom to send the problem hard drive to.
There are a couple of videos on youtube showing how to remove the cover. I wound up using credit cards and a DVD to pry it apart. I was fearful that a screwdriver could create noticeable tampering.
Posted on Sep 29, 2008
My western digital 500gb hard disk light is not on. It was working so fine. I'm not able to understand the problem
hi
i have the same unit ..eventually if the unit is not unplugged and plugged in in sequence as i describe here, the power module will be expended.
when disconnecting , you have to unplug AFTER you (via software, S/W) disconnect from the ICON found at the bottom right corner of the computer screen , After disconnecting via s/w, unplug the USB cable, then the power cord.
when reconnecting, plug in the power cord, wait 30 seconds, then plug the USB cable in .
this should alleviate the issue at hand. if the unit does not function, then the power module inside the hard disk drive housing is no longer working
i hope this helps
send me 4 thumbs up please.
Aug 17, 2011 | Western Digital 500GB My Book World...
Problem with WD 1.5TB external hard drive
This appears to be a common occurrence with the My Book. It may be a heat dissipation problem from leaving the unit on for longer than it takes to back up your data.
I think you might need technical support from Western Digital. Do you have an alternate backup?
Mar 21, 2010 | Western Digital My Book Essential Edition...
We purchase western digital 500 gb hdd when pc is
The blinking of the lights is just the indication that data is being accessed.
Mar 19, 2010 | Western Digital My Book Essential Edition...
My Western Digital My Book Essential Edition 500 GB hard drive was working fine, until the power cord was removed accidentally. Now I can't get any computer to recognize the drive when I plug it in the USB...
Is the power light on, if not replace the power supply.
I f you have light then your hard drive is shot or the circuit inside the box is fried.
If it is out of warranty and you have another Western Digital Sata drive handy you can swap it with the one inside to see if the drive is bad.
Good luck.
Dec 21, 2009 | Western Digital My Book Essential Edition...
My book western digital harddrive 500 gb
If it is under warranty contact Western Digital normally they carry a 3 year warranty. The HD is bad.
Aug 25, 2009 | Western Digital My Book Home Edition 500...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
My external hard drive won't turn on
Ok, this just happened to me, my western digital my book studio external drive was not booting up, i could hear the disk spinning, but it would then cut out and the light on the drive was never turning on. i called Western Digital customer support and found out that the proper way to connect a drive is to plug in the power cable FIRST then the data cable. Also, with the My Book Studio Edition you should never have to press the power button, the drive just turns on when you plug it in. Hope this helps somebody...
Feb 18, 2009 | Western Digital 500GB My Book Pro-External...
Western Digital External Hard Drive Won't Boot Up
Take it our of the external encasing and plug it in directly to your motherboard. This has worked for me in the past. I just had my second wd external harddrive crash so now I will do the same process all over again.
Jan 26, 2009 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
1,137 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
