Question about AT&T E2120 2.4GHz Cordless with Alarm Clock Radio Phone
My att e2120 telephone clock radio
The numbers have faded and are not readible. is there something i can do?
  • Anonymous Dec 01, 2008
    We have the same problem with our 5 year old phone and don't have an answer for recovering the LCD.
  • Anonymous Dec 03, 2008
    I have the same problem except mine happened when I spilled a little water on it. The rest of the phone is great but I cannot see all the numbers. Any ideas?
NEED A MANUAL. WAS GIVEN A RCA RP3710A CLOCK RADIO, USED. NEED A MANUAL TO SHOW ME HOW TO SET AND RUN
Thomson / Alcatel - Technical support Contact Number Try there support. This is a UK one, if you are in USA go to the website for local number.
Telephone number for Thomson / Alcatel - Technical support:
Thomson / Alcatel - Technical support Telephone Number: 09063022114
Thomson / Alcatel - Technical support Contact Number: 02073090226
Aug 19, 2010 | RCA RP3710 Clock Radio
Projected image on Emerson SmartSet faulty.
You will have to call Emerson customer support for this type of repair. What happened is the display circuits have been damaged in the fall. You can call the customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio. Ask them where you can find a authorized service center in your area. Try to get a telephone number. Call the service center and ask them if they do out of warranty repairs. If they do tell them the problem you have had with the Clock/Radio. Ask them to give you a estimate of the cost including shipping and handling before having it repaired. This way you can judge whether it is worth it to repair the Clock/Radio or replace it. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
My Emerson clock radio was manufactured in 2001. Model #CKS2000N; S/N10339233BA. Need to set clock for DST. I do not have a "month" year button - only a "time" year button. Can you help? Thank you
For this model Clock radio you will have to call Emerson Customer support at this telephone number.1-800-909-1240 between the hours of 8am-4:30pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance. You will probably be told that,your Clock/Radio has no updating feature. This is because at that time there was no need for such a feature. The best way to get the new features is to buy a new Clock/Radio. Thank you for using FixYA and have a nice day.
Mar 05, 2009 | Emerson Smartset Clock Radio
Flickering and faded display
Have same problem. Cheap company, no POC phone number in handbook, no address.
Aug 02, 2008 | Cambridge Soundworks CD-740 Clock Radio
Numbers faded on clock radio
well it sounds like the LED's inside are going out....if you have experience, you can buy some new LED's from alot of places, radioshack is where i buy mine. then just install new LED's...or you could get a new clock thing.
Jun 28, 2008 | RCA RP5430 Clock Radio
Smart set clock dead ?
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
May 18, 2008 | Emerson Smartset Clock Radio
Alarm
Feb 14, 2008 | Emerson Smartset Clock Radio
Alarm not working
Oct 26, 2007 | Emerson Smartset Clock Radio
AT&T E2120 2.4GHz Cordless with Alarm Clock Radio Phone Logo
115 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
