Cant remember the password or username to access my router
  • 661 Answers
The default login should be in your quick start guide.....
this will work unless you have changed the password.
If you really need to access settings , you can perform a factory reset which will wipe out all settings and reset the password back to the default
Posted on Sep 28, 2008
  • 300 Answers
Depending on the type of router, there you be a factory reset button on the back of the eqpt that you can insert something about the size of a paperclip into for about 10 seconds while the power is on.
NOTE: Once this is done, you will lose all configuration and passwords on the router. After that, you can refer to the manual for the default password on your router. Some routers have default passwords and others you can leave blank.
Hope this helps. Please remember to rate this information.
Thanks
What is the default username and password for a Linksys/Cisco Wireless -N Home Router to access web-based setup
Connect to http://192.168.1.1/
The default password is "admin". No username required. If you don't remember the correct password and you don't want to use some brute-force cracking software the only option is to reset the router pressing reset for 30 seconds. After that everything should be back to factory defaults including the default password.
If you need any kind of technical assistance you can contact support cell at here
Jan 21, 2013 | Cisco Linksys Wireless N Home Router...
This router was previously used by my sister-in-law in manila...then i brought this router in japan...when i want to install it in my computer i cant access on the site that written in the...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your
router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 08, 2011 | Computers & Internet
How do I find my wep key? I cant remember it and cant get online wireless with out. I did go to http://192.168.0.1/login.asp but I cant seem to log in there. Please help.
Try to access 192.168.0.1 once again. Try to use "admin" for the username and "motorola" for the password. If "motorola" doesn't work, try "password".
Sep 03, 2011 | Arris SURFboard SBG900 Wireless Router...
I cannot find or remember the password for my E1000 Linksys router
Hi the default password for linksys unless you or someone has changed it is:
USERNAME: leave it blank PASSWORD:admin
If this would not work and you cant access the Linksys you need to reset the router by poking the reset hole at the back of it.Thanks
Feb 01, 2011 | Cisco Linksys Wirelessn Router Black...
Can't remember wi-fi password
hi spues,
If you cant remember the Network Key you can access the Wireless Router Page so that you can obtain the information and you can personlize it aswell. To access the router page just open a browser then type http://192.168.1.1. the username is admin and the password is password. Go to the Router Settings Page. Look for the Network Key. Personalize the information so that you can easily remember it.
Rate me if this helps so i can help others.
Thanks for using Fixya.
Jan 31, 2011 | NetGear WGR614 Wireless Router
I can`t access router setting. I haven changed user name an pass. I tried to shut down the router an wait for an minute. Then I turn it on an tried to access 192.168.0.1 . After than in the username field...
If you cant remember the username and password of your router you can reset it to bring back the default settings of your router to be able to access it. At the back of the router you need to press and hold the small hole using a pen or a paper clip for 10-15 seconds. after that the router will return to its original state. Keep in mind that it will remove all the settings that you've saved. Then access the router using 192.168.0.1 and using its default username and password
Jan 27, 2011 | Levelone CP TECH WBR6002 Wireless Router ...
I cant log in with my username and password
Reset the router to factory defaults by putting in a push-in in the small hold at the back of the router. You should then be able to login using the default password. Default password should be in the user manual.
Dec 05, 2009 | Arris SURFboard SBG900 Wireless Router...
Linksy router lem....!!!!
Try the following to reset it to the factory defaults.
Warning! This will reset all the settings in the router! Including any custom setup stuff, like WPA key, etc.
Turn the router on. Press and hold the reset button on it for 30 seconds. The reset button is usually a small recessed button on the back of the unit depending on which model you have.
Now you should be able to connect to it through your browser at http://192.168.1.1. Depending on your model, the username is blank and the password is "admin" (without the quotes) OR both username & password are "admin". Note that you will need to connect your computer to the router with a network cable to go through the setup process - you can't do it wirelessly.
Dec 13, 2007 | Zyxel P-334WT Router (91003155003)
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
