Question about Sangean HDR-1 Radio
Volume varies I have just started using my new HD table top radio. I love the quality, but have a problem with the volume (broadcast) on both AM and FM fading just a bit, then coming back strong. The stations are never lost but the volume varies. It is annoying. I live relatively close by air 15 miles, from the KMOX transmission tower. It is a 50K clear channel station and appears to have a very clear signal, yet the volume wavers just enough to be noticed. This also occurs on FM stations. Is there anything I can do to improve this? I have moved the external AM antenna to different spots to no avail.
5 Suggested Answers
  • 3 Answers
SOURCE: external antenna
You can get good assistance at the DX 398 Group at Yahoo! The DX 398 is the same radio as the ATS-909. It was the name used by Radio Shack when they marketed it. Here's the URL for the DX398 group: http://groups.yahoo.com/group/DX398/ They will definately welcome your questions and will likely provide some valuable answers.
Posted on Jan 06, 2008
SOURCE: Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Posted on Aug 06, 2008
radiorob1
  • 17 Answers
SOURCE: Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Posted on Aug 04, 2009
radiorob1
  • 17 Answers
SOURCE: No reception sometimes
Either this is typical shortwave reception characteristics, or you intermittent antenna connection.
Posted on Sep 06, 2009
Dx-L321-10A: M-B315AA on direct tv. Can't get HD. Says restricted. Tried comp. No good, haven't used HDMI. Do I need Digital? Thanks for your time.
These are directly from your users manual:
  • Built-in HDTV tuner: Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming
  • 2 HDMI inputs: Provide an uncompressed all-digital audio/video link for the highest quality connection and support copy-protected HD broadcast content.
  • you need to do one of 2 things to get HDTV on your device. Either attach an HD- capable antenna or attach an HDMI cable from your satellite tv providers box. Good luck.
Aug 03, 2015 | Televison & Video
Brand new TV with Light leakage on the screen
I happen to have the same tv brand, size, and problem. The only difference is model. I bought mine black friday 2012 and its got screen problems. Im looking for a solution also to why it has the problem it has. It was working great for the time being until i noticed cloudy white spots around the perimeter edges. I found out its do to a few possibilities. One is the one thats wrong with mine that i believe is dead pixels. My tv doesn\'t look damaged in the screen butt when the image darkens while watching tv u can see it. Its like a bleeding discoloration. Me personally im taking mine back to either get my money back or new tv. From ur breaf description sounds like u have the same issue except yours came that way.if u look at my follows on here u will see pictures of my tv and the issue to my screen. I bought mine from best buy. So i got a thirty day store return warranty plus i purchased a 2 year warranty. So im going back and going to see what they are going to say. I advise u to probably do the same especially if u got warranty.
As far as changing ur setting for HD picture quality with ur dish is to go through your menu options on the dish.i use comcast so mine is different butt im sure in a way the maybe might b in somewhat similar. With comcast theres a format button on the front of my box that i can press to change different format quality. If that dont give u what your looking for then see if you turn off your box while tv is on and then press menu on box and see if a user menu pops up if so then u should be able to change quality. You then can program it to be 1080 if ur using hdmi or components. One thing with comcast box is that i can make every channel 1080 bt the regular channels that dont broadcast that quality makes the picture smaller. So then u have to have HD channels to get 19080 quality. Butt u can get a good quality setting still with regular broadcast channels by overriding to 480p or to the best quality its puts out to that channel. Most broadcast channels set out a 480i or a a better HD 480p. Other than that you have to have HD channels and then ur box should automatically format to 1080u quality on the HD dish channels so you dont have to keep changing. Then when change ur channel back to standard broadcast channel it will automatically format to back to 480peither and so one as you change channels. Well hope it all helps and you got what you were looking for.
Dec 04, 2012 | Westinghouse " 46"" Class - LED - 1080p -...
How do I set my clock on my accurian table top hd radio?
1. Turn on the radio
2. Hold down the "Clock" button. It will switch to clock-date setting mode.
3. Use the "Tun-" and "Tun+" buttons to adjust each field.
4. When one field is set, push the "Clock" button to get to the next one, and when all are set push it again to exit.
Aug 21, 2011 | Radio Shack "Accurian" Tabletop HD Radio...
How does it help to have a Full HD LCD TV?
Hi - welcome to Fixya,
There is no advantage in buying a Full HD (1080p) TV if you are only using it for watching TV. Currently, there are no Full HD television broadcasts and there are no plans to introduce any. All UK HD channels currently broadcast in 720p resolution whether they are on Sky, Freeview, or Freesat. Therefore, any TV that is described as 'HD ready' rather than 'Full HD' will display all HD channels at maximum quality or resolution.
The advantage of Full HD is when using them with Blu-ray DVD players, gaming systems, e.g. Sony Playstation, or for playback of media files from your PC. These systems output at 1080p / Full HD (but only when connected with an HDMi cable) and you would need a full HD TV in order to get the best quality / resolution from these systems. However, you don't need a Full HD TV to connect these devices as they can all display their output on a 720p HD Ready TV.
The main disadvantage of any HDTV (1080 or 720) is when watching standard definition (SD) broadcasts. Full HD TVs have 1080 horizontal display lines, but SD broadcasts only have 540 horizontal lines. When watching SD channels on an HD TV, the other 540 lines, i,e half of the picture, are being created by software within the TV - known as 'Upscaling'. Upscaling requires processing by the TV which takes time and fast motion can seem blurred or blocky/pixellated as a result. Higher end TVs have faster response times (0.5ms or less) which minimises the pixellation so this specification is important when selecting an HD TV for purchase.
Hope this helps.
Regards,
BElectric
Nov 18, 2010 | Samsung Televison & Video
How do i get my built-in freeview to work?
I have freeview inbuilt on my tv. I hav sky at the mo so hav the satellite dish but want to get rid of sky and just hav freeview. So how do I make freeview work? Do i need to buy some sort of cord/connection to hook up the satellite cord/connection to the tv?
Oct 14, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Milwaukee Jobsite Radio 49-24-0200 Ser.-414c Volume Fades
the volume control needs to be cleaned. if you can carefully take the back off, the volume control may have some small openings in the housing. spray contact cleaner (or even a small amount of wd40) in it and work the control back and forth and see if that does it
Aug 09, 2009 | GE Superadio III AM/FM
Need to make sure programmed
Program the Midland 74-109 Weather Radio
a) Turn unit on. Extend the antenna. Adjust volume up slowly; Do you hear anything? If not, try replacing the 9 volt battery with a fresh one, in the accessible battery compartment underneath the unit. Repeat above steps.
b) If no sound is heard, turn unit over and look for "WEATHER" slide switch on bottom. With unit on & volume adjusted to comfortable hearing level, slowly slide switch down (or up) through various frequencies [1)162.550, 2) 162.400, 3) 162.475, 4) 162.425, 5) 162.450, 6) 162.500, 7) 162.525] until voice transmissions are heard. This should be the closest National Weather Service (NWS) broadcast for your area. Check the NWS website at http://www.nws.noaa.gov/nwr/nwrbro.htm for your state, click on the state name, and look for the site name or site location nearest you. The frequency for that site should be the strongest, and appropriate for your area.
c) You can set the alert tone, for special weather alert broadcasts, on the bottom of the unit on the slide switch marked "ALERT". Set the switch to the desired type of alert: 1) LED [LED on top of unit (marked ALERT) lights up when alert is broadcast-no siren tone/alarm is heard] 2) LED & ALARM [LED lights up and alarm/ siren tone is heard] 3) VOICE [LED on top of unit lights up and voice broadcast is heard, only; no siren tone/alarm is heard].
d) Be sure to press the "ALERT" button on top of the unit and leave the volume at a comfortable listening level to hear weather alerts for your area (Alert LED on top of unit lights up to show Alert function is active). You can test the present volume level by pressing the "TEST" button. Be sure to press the "ALERT" button again after listening to the volume level to re-set the Alert function. You can listen to weather broadcasts anytime, by pressing the "WEATHER" button. After listening, be sure to re-press the "ALERT" button to reset the Alert function.
e) 9 volt battery life should last about 6 to 7 months, depending on how much unit is used an number of alerts received. Replace battery every 6 months, or when you replace your smoke alarm battery, or at beginning and end of daylight savings time. A 12 volt AC adapter to replace the battery, can be used. One should have been supplied with unit. If not, a replacement can be found at Radio Shack.
f) This should complete your Midland Weather Alert Radio Model 74-109 programming.
Apr 09, 2009 | Midland 74-109 Weather Radio
Poor sound cqality on a Samsung DLP TV
If you are receving your HD via a cablebox, check the volume and audio settings in the box's menu. Some boxes have internal volume controls. If the level coming out of the box is below a certain level, you may experience low or poor sound quality. You can also check the audio settings to assure that they are set to the original settings.
michtech
Feb 19, 2009 | Televison & Video
Sangean HDR-1 Radio Logo
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
