Question about Frigidaire Washing Machines
Washer will not begin cycle because the "dr" indicator comes on. automatic door lock seems to be malfunctioning. is this an easy fix without the need for costly repair men? Frigidaire - affinity model # LTF6000FS0
  • Anonymous Mar 28, 2014
    Replace outer door
  • 1,122 Answers
Easy fix,if you go to sears .com click on parts put your model number in it will break down and show you everthing about the part and where it goes,let me know how it turns out-mike
Posted on Sep 28, 2008
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
My LG WM 1812CW turns off soon after the first spin. No error message.
Seems that the main panel is defective. The fault suggests that the program controller or the processor is malfunctioning specially when it works for some time. If you can check on the +5 volt to the processor , the power supply factor can be established as a faulty supply or a blown mains capacitor can also shown this fault .
So remove the panel and check the components for any visible signs.
Jan 14, 2013 | LG WM-2277HW Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
"Pause" will not give way to the selected cycle
Turn off the machine then unplug it for at least 15 minutes and plug it back. Turn the washer on then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it. Include also the exact model number of the machine if the foregoing instructions don't seem to be applicable with your machine.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Oct 03, 2011 | Frigidaire ATF6000ES Front Load Washer
Don't see any problem with my wahsing machine, but the "dr" keeps signalling on the washer keeping it from operating. What do I do, the door seems to shut fine?
DR is door error
This generation of dryer has alot of control board failures(the relay for the heat burns the terminals for the wires), you can inspect these relay connection visably by removing the front control panel
This is indicating an open door circuit. Since the circuit cannot complete, you cannot program any cycles and the "clean filter" light will remain on until you can do so. You will find a technical data sheet inside your dryer, either just under the top panel, or inside the lower panel, if so equipped.
Hope helps.
Jul 28, 2011 | Frigidaire ATF6000ES Front Load Washer
Do you know how to fix the "door locked light"
The door lock light indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Mar 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Flashing "DL" with 3 or
The'DL' symbol indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
PS my daughter and fiance call me 'superjohn'- at the age of almost 70!
Mar 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have the frigidare affinity front loader washer and just started it up. It stopped about 5 mins into the cycle and the indicator light says dr. I tried to shut the door but that didn't work. So I...
You need to replace the door lock mechansim. Fairly easy to do yourself, just pull the spring strap off the rubber door gasket and remove 2 screws holding door lock. Install new door lock and re-install door gasket and spring strap, and WALLA! she works:)
Nov 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Says "dr", will not start
The error clearly indicates bad door switch. Very simple to fix, have to take top off and loosen switch from front panel. Remove and replace.
Part #131763245 and suggested retail price $50.
Thank you
Jun 14, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
182 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
