Question about Sharp AR-5316 Advanced Digital Imager Copier
Fix mantainance and developer leds
I need to reset the manteinance and developer codes which are on despite the fact that the machine is working normally.
  • 1 more comment
  • caanne Oct 04, 2008
    The machine has only done 50,000 cycles. Does it still require change of developer even when the copies are super clear.
    Also if i may ask, what parts / areas need to be checked and if they are o.k. what buttons do i need to push to see the damn LEDS off. Please assist
  • Tim Babcock
    Tim Babcock May 11, 2010
    If the developer hasn't been changed, the copy quality will diminish very quickly. It might be fine now but it will change within the next week or two.
    That should be replace first, cablibrated, and then the codes can be reset.
  • Tim Babcock
    Has the developer been changed yet? It should be done at 150,000 cycles.
  • Sharp Master
  • 2,794 Answers
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
To cancel the test command mode, press the [CA] key.
Press 26. Press the green button.
Press 36. Press the green button.
Press 1. Press the grreen button.
That will cancel the drum reset. The machine will ignore the drum reset at 50,000 cycles.
Posted on Oct 10, 2008
What's your question?h how can i fix m2 in konica minota 213 ineo copier
Reset the drum and developer counters to zero, the replace the developer, and run the required TCR adjustment. Do NOT reset the counters then think you don't have to replace the drum and developer, because the copier uses the counters to determine voltages for certain parts inside the machine, reset counter and not replace the parts the copier thinks they are new when in fact they are old you get codes and bad copies.,
Feb 02, 2016 | Konica Office Equipment & Supplies
How to enter f8 function in konica minolta ineo250
Utility/counter, details, stop 00 stop 01, function F8 was developer replaced before you do this WAS THE DEVELOPER COUNTER RESET before you put the new developer in. The machine runs on the counters if you did not reset the machine will think the developer is old when in fact it is new and will cause image issues and codes
Nov 01, 2015 | Konica Minolta Office Equipment & Supplies
How to reset imaging unit for konica minolta bizhub211
IS the drum cleaning blade and developer been replaced. Counters are to be cleared before replacing the drum and developer, because the machine use the counter to determine voltages to certain assemblies. If you reset the counter and have not replaced the parts then the machine will think the parts are new when fact they are not and cause image problems and codes. Was the F8 run after new developer was replaced. DO not allow any printing or copying until that is done, or you will have to replace the developer again.
Feb 19, 2015 | Konica Minolta bizhub Office Equipment &...
How to clear counter of Minolta bizhub 163.At present its showing ERROR "MAINTAINANCE CALL 2"
Need to have the drum and developer replaced first. Then clear the counter. Not replacing the drum and developer and resetting the counter will cause image problems and codes due to the fact the copier uses the counters to determine voltages to certain units. and is the only way the machine has new parts. You reset the counters and not replace the parts, then the voltages will be set for new parts when in fact parts are old.
Jan 15, 2015 | Konica Minolta bizhub Office Equipment &...
How to reset developer on konica minolta 7216
You do not reset you replace the developer reset with out replace tells the copier developer is new and machine sets voltages according when in fact developer is old causing codes/ image problems
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
May 05, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Reset error m2 in konica minolta 164
Replace the drum and developer first. Resetting counters with out replacing parts is not good. The machine works on base on counter info you reset counters then not replace parts the copier will adjust voltages on certain items when in fact they are same items image problems and codes.
Jan 13, 2014 | Minolta bizhub 180 Black and White Copier
Devloper reset code
Has the developer been replaced? If not reset code for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counter with out replacing the require item the copier will adjust certain voltages to certain items such as the drum and developer system as those there are new because you reset the counters when in fact he developer is old and so mite be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared and was the required F8 checked run?
Dec 15, 2013 | Minolta bizhub 200 All-In-One Printer
Minolta 450 di error code COF32
Have the developer replaced. if you have had the developer replaced and that person used a vacuum cleaner to remove the old developer then the static electricity from the vacuum cleaner destroyed the sensor underneath the image unit. Worse case the main board that sensor feeds is bad now. Go with replacing the developer again first. Then worry about the sensor or the main board. Was the counter reset when the developer was replaced, was the F8 process done after the developer was replaced.. If not then get new developer have the process done correctly, the machine works on what the counters have in them if you replace the developer and don't clear the counters the machine will assume the that old developer is in the machine and adjust the voltages to certain units accordingly when in fact new developer and for that matter the drum also works on that system. is installed causing image problems and codes.
Mar 10, 2013 | Minolta Office Equipment & Supplies
Hi i got xerox phaser 7750 and i have error code
Cheap fix : reset the Developer Life Count in the Service
Tools menu. Hold down the back ARROW key with the "i" them with your other hand turn on the machine.
Expensive fix : What has happen is that the developers have come to the end of the life and once it gets to a certain page count it will print out no more until you have replace the developers. One thing xerox forgot to do is reset the engine control board too for this machine. So you might need a new engine cotrol board too.
Procedure
1. Replace the Developer
2. After the Developer has been replaced, reset the Developer Life Count in the Service
Tools menu.
NOTE: It is recommended that all the Developers and Beads be replaced at one time rather
than on sccessive visits.
Good luck.
Oct 29, 2009 | Xerox Phaser 7750DN Laser Printer
Computer dead despite working power supply (power and charger LED are off)
Try removing the battery. It might be damaged and overloading the laptop. Also, before you replug the AC cord, press power for at least 5 seconds.
Oct 31, 2008 | Toshiba Satellite A215-S7422 Notebook
Sharp AR-5316 Advanced Digital Imager Copier Logo
153 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
