HP iPAQ HX2490 Pocket PC
Problem for HP iPAQ HX2490 Pocket PC
How do you hard reset a hx2490
By Rogers - usenet poster
Same Problem
Nov 26, 2008
-   hello i have forgotton my password to my ipaq 2490b what do i do can anyone help -   nedler_1
Sep 18, 2008
-   Forgot my password. Tried a hard reset but it still is requesting I enter a password.-   leelafr
Sep 02, 2008
-   how do you reset a hx2490b to fsctory defsult -   pcrepairs2
Jun 11, 2008
-   I need to do a hard reset of my hx240 by software because Ipaq is into a robust box without mechanical access to buttons, do you have any soft that I can run in order to do hard reset?-   Jorgecalvi
Best Solution
posted on Dec 27, 2007
Very Helpful)
rostockdea
Rank: Apprentice
Rating: 97%, 27 votes
Thnak you so much this worked perfectly after my IPAQ suddenly decided that it had a password when it did not.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 29, 2008
Very Helpful)
mike001234
Rank: Apprentice
Rating: 96%, 21 votes
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #3
posted on May 30, 2006
Very Helpful)
kcw573
Rank: Apprentice
Rating: 0%, 0 votes
if you have WM2005 try this, press power, calendar and mail buttons while inserting the stylus. it will clean reset the WM2005 which cannot otherwise hard reset because of persistant memeory. you'll lost everything in filestore.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Sep 20, 2008
Helpful)
marcred99
Rank: Apprentice
Rating: 93%, 6 votes
I FORGOT MY PASSWORD AND NOW I CANT DO ANYTHING. WONT GO PASS THE PASSWORD SCREEN .WHAT DO I DO . DONT KNOW HOW RESET THIS (HP IPAQ 1955)
Was this helpful?
Yes
No
Solution #5
posted on Jan 23, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Worked GREAT thank you very much !!!!
Solution #6
posted on Aug 01, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
thanks I follow your advice to hard reset my HP iPAQ hx2490b as you said and it is succesfully done thank for your note
Abi, cob
Solution #7
posted on Feb 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ok, thank very much for you turotial and how to edit here, thanks!
Solution #8
posted on Dec 17, 2008
Very Helpful)
Tier78
Rank: Apprentice
Rating: 100%, 1 votes
In spanish:
1. Presiona y mantenlos asi(presionados) los botones calendario y task
2. Mientras los tienes presionados utiliza el stylus el boton de reset durante unos dos segundos
3. Cuando la pantalla comience a desaparecer libera los dos primeros botones q te dije y despues retira el stylus del boton de reset.
4. Enchufa la pocket en el adaptador de CA o presiona el boton de reinicio otra vez.
Ahora q si lo q quieres es un reinicio limpio para dejarla x defecto de fabrica haz lo siguiente:
1. presiona y mantenlos asi los botones calendario,encendido y mensajeria
2. mientras los tienes presionados introduce el stylus en el boton de reset hasta q la maquina se reinicie
3. cuando la Ipaq se reinicie libera todos los botones y x ultimo retira el stylus, entonces
ella sola se reiniciara....
te adjunto un pdf donde muestra los botones para q no te confundas, es de la mia pero en teoria funcionan de la misma forma, espero q te sirva ese hard reset..
Was this helpful?
Yes
No
Solution #9
posted on Oct 30, 2008
Not Rated)
rap_rick09
Rank: Apprentice
Rating: 0%, 0 votes
how to perform hard reset to my hx2490b
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ HX2490 Pocket PC
Questions and Unsolved Problems for HP iPAQ HX2490 Pocket PC
Do you recommend HP iPAQ HX2490 Pocket PC?
Answer
Answer
cannot connect to wireless connection. Network shows up shows available but unable to connect
Answer
how do i read the operating instruction
Answer
my align screen won't go away after hard reset what do i do?
Answer
HP2490IPAQ WHEN I TRY CONNECTING TO A WEBSITE IT SAYS ADDRESS IS NOT VALID //CHECK AND TRY AGAIN
Answer
when I connect the Ipaq 2490, the screen lights up but no image. PC connects to the PDA, but PDA... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDA Experts
Top Computer & Laptop Repairmen
in , OH
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
