DVD deterioration I have burnt several DVDs using several brands of DVD blanks. After some time, say four to six months, when I play aome of them, at the end of the movie it suddently freezes  and the film refuses  continue. Toching the freeze frame, or play buttons or any other buttons on the remote control gives no help. After a few minutes, the player stops.  Upon checking the discs, I can see no physical damage at all. Careful cleaning doesn't help. My storage situation is fine, No moisture or high temperature. Other discs work fine using my player. Are the discs deteriorating? Am I using bad blanks? Thank you!!!
    Master:
  • 405 Answers
I would blame it on the DVD player. They are fickle when it comes to playing burned discs. Try playing the disc in your computer. If does the same thing there, the disc is garbage. You can also try burning at a slower speed, sometimes this helps. I would also try to avoid using DL (dual-layer) discs.
Posted on Apr 09, 2017
  • 82 Answers
SOURCE: movie skips and freezes during play
CD and dvd disc cleaners will not solve the problem, a deeper and delicate cleaning procedure by cleaning the lens manually with an cotton swab is needed...
Although the quality of newer discs is to be discussed.
Posted on Dec 08, 2007
  • 4234 Answers
SOURCE: tevion player shows BAD DISC,
Since the unit is under warranty, you can't touch anything without voiding the warranty. This problem could be as simple as a dirty lens. Bring the unit in for repair under warranty.
Dan
Posted on Mar 19, 2008
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
SOURCE: JVC XV-THA5R multi-region DVD player - fault recognising a disc in and playing
I too have this same problem on my current DVD player, AND strangely enough I had the same problem on my previous player.
Previous player was made multi region and was a Sony S660 (I think that was the model number).
My current DVD player is a Denon and was £550! It is also made multi region and has the same problems! I don't get it!
Posted on Apr 23, 2008
SOURCE: will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
Posted on Jul 18, 2009
My dvd player on recognizes original dvds but wont read any burnt dvds...WHY???
most of the laptop dvd drives have slower reading speed(about 2x) and writing speed(about 24x) compare to desktop pc's(about 8x and 52x respectively).
ur problem might have occured if the writing speed by which the cd was burnt might not be compatible with ur dvd player.
try playing dvds which were burnt using laptop dvd writers.
also try changing the modes in which the dvds are burnt.
Jun 19, 2011 | Lenovo 3000 Y410 (59012354) PC Notebook
Says no valid disc to several brand new dvds.
Has to do with the differeint codes on cd
Sep 13, 2009 | Toshiba Televison & Video
Can't burn DVDs on new Toshiba Portege m750 Tablet
hi, toshiba computers commonly used tool is called burnt record now, it works properly, that you get at the start + all programs + sonic + record now, try using this tool, if the fault persists, you should have problems with your unit cd-dvd
Jun 08, 2009 | Computers & Internet
What recordable dvds will play in philips HTS3400??
it might be the programs your using to burn your dvds try using windows dvd maker if you have the operating system vista or convert x to dvd if you have xp that should work
May 30, 2009 | Philips HTS3400/37B System
The player plays most every DVDs I burnt. However, I bought identical DVD-R and DVD+R from Staples and SPIN-X brands and it says DVDs unknown. What is the problem?
This player can't recognize DVDs that have a write speed that is greater than 16X (and it sometimes has problems with discs above 8X). I would only buy brands that the manual reccomends as tested. This player also won't accepted what are called "Variable" or "Variable Speed" DVDs.
-Tha Mp3 Doctor
Feb 25, 2009 | Philips DVP5960
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
I/o error
If I were you I would go up on toshiba's site and down load the updated firm ware for the laptop.
Select which model A105 you have, Click on show results, click on downloads, and search the 1-4 pages of downloads for the dvd/dvd rom updates. Download install, and rerboot to take effect.
May 14, 2008 | Toshiba Satellite A105 Notebook
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
Phillips DVDR3320V 'disc unknown' error
Hey there,
Have you tryed different types of DVDs. You might need to buy DVDs that say DVD RW.
Jan 27, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
