Question about Toshiba CZ27V51 27" TV
Toshiba CZ27V51 27" TV 1999 - Picture goes out
One of the truly great Analog TVs that I have had for 8 years. The picture now gose out with a blip and a buzz. No line, just a black screen. However, if you jiggle the TV or whack it on the side, the picture comes back. This seems to be taking longer and longer with more jiggles and slaps, hehe. Anyway, once it "catches", it can stay fine for quite a while.
When the picture does go out. The Power On light, flashes slowly.
--tom
techman
  • 3130 Answers
SOURCE: Power on but no picture or sound
Your problem is from the power regulator IC . Its an str type and has to be an original from tosiba or its parts distributors. Now you may have caused more problems as alot of peeps do trying the set over and over again thinking Oh the set will rest its self.. Nope sorry sir if a set goes bad and you try it once , and it dosent come back on . Its time to seek a repair person to repair and troubleshoot the set for you UNless your a technician? If your not Dont try to repair a tv as these have non serviceable parts for the consumer to replace! And can bite ya in the butt, if your not carefull. We techs cannot teach ya overnight how to fix something. Only assit and to point ya in the right direction. Good Luck
Posted on Jun 24, 2006
SOURCE: Picture Jumps/flashes for first 5 minutes
I had the same problem and followed the instructions from Jack and my 57h81 is bak up and running. Thanks Jack. RonD
Posted on Oct 09, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 43A61 - No Picture, no sound
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash. In this case, you need to call a service tech. Most of the time, however, the unplug/replug routine is enough to get the set up and running.
Posted on Dec 11, 2007
Benimur
  • 6966 Answers
SOURCE: No picture Thin line across middle of screen
Most problems indicated by your description involved the Vertical IC. With your post "tap...pop back up" signifies a loose connection or to be more specific a cold solder. I suspect that no part(s) need top be replaced but would however require re-application of heat with the use of a soldering iron.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Feb 19, 2008
  • 375 Answers
SOURCE: 32" Toshiba Television suddenly quit working
by the age of the unit it sounds like cold solder connections, on the main board
Posted on Mar 27, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
No picture, on/off switch does not work, and there is a constant buzzing.
This tv high voltage is dead.The FBT-the flyback transformer is not giving any more high voltage.The big black block of plastic,with a red wire with a cap hook to the CRT-tv tube.Analog tvs are hard to find parts these day.If u have soldering iron,solders,soldering wick or desodering pump.Can do soldering?Repair it urself?Might can find analog tv parts on Ebay.com.
Sep 09, 2010 | GE 32GT720 32" TV
Picture freezes
this is a great factor with the weather EVEN CABLE TV IS THROUGH SATILLITE !!!! there could be bad weather 50 miles away and it will affect your signal..........
Jun 21, 2009 | Insignia Digital-to-Analog Converter for...
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
Black line across screen
module problem take it to a Authorized dealer or a NESDA dealer service manuals hard to say if available since analog TVs are slowly going away and parts well another story might as well go buy a new HDTV set as a CET no garuntee how long it will be analog TV parts will be discontinued. FCC has alot to do with it.
Apr 16, 2009 | Televison & Video
Black box in front of picture
If it's the box,just press the CCD button on the controller until you see CCD off .(Try this one first since it just started with the box)
If it's the TV,just go into the setup options and turn off the closed caption feature.
Jan 07, 2009 | Insignia Digital-to-Analog Converter for...
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Vertical Lines / Color Differences at edge of Analog vs HD Picture
EXACTLY-YOU HAVE THE USUAL "AGING" CRT PICTURE.THIS WILL ALWAYS HAPPEN WHEN YOU WATCH THE TV W/BLACK BARS ON THE SIDE,THERE IS NOTHING SHORT OF ALL 3 CRTS' REPLACEMENT TO FIX IT. JOE TV
Oct 31, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Toshiba CZ27V51 27" TV Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
