Dryer plumbing leaked machine spins2secs.stops,pumps out,same cycle repeated
Zanussi wj 1265 washer/dryer i located a leak in the plastic plumbing that goes to water inlet tray a screw that holds the fan assembly was missing and due to vibrations the top part of the plastic pipe came off which would cause foam and water to spill on the floor i fixed the pipe but machine takes water and starts to spin for 2secs. and stops and then the pump kicks in and pumps the water out and it keeps on trying to spin but only for 2secs then goes quite pump tries to pump water out where as theres no water left in the machine. i left it to dry for few days but its stuck in the 2secs. spin mode no matter what you do i also tried to see if only the dryer works without selecting any wash cycle but the results are the same the pump tries to pump water out which is not present and then spins for 2secs. exactly and cuts out spinning before it can gain any speed.
please can you suggest possible causes so that i can check as i am in pakistan and there are no repair centres here.3months ago i replaced the main drum bearings and it was working fine untill this happened. your promp help in this matter will be highly appreciated thanks.
  • kalsoomabid Sep 28, 2008
    i tried that but it doesnt work even with the machine being kept unplugged for a few days
  • 750 Answers
Hello kalsoomabid,
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huuum
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
Small amt of water drips into tub after washer stops fisher payke
If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
  • thanks and please do not forget to accept the solution
Apr 03, 2009 | Fisher Washing Machines
Washing machine is leaking water.
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
Nov 18, 2008 | Frigidaire FEX831CS Top Load Stacked...
Zansuai
If the oven doesn't heat evenly or doesn't heat at all, the oven thermostat may be malfunctioning. First, determine how much the temperature in the oven is off from the control setting. To do this, put an oven thermometer on a center rack inside the oven and turn the oven on for about 20 minutes, with the thermostat set at any range between 300 degrees and 400 degrees Farenheit. If the oven thermometer reads 25 degrees or more lower or higher than the oven control setting, the thermostat should be recalibrated. Here's how to calibrate the thermostat:
Step 1: Pull off the thermostat knob on the control panel. Behind the knob are two screws holding a round, notched plate. Loosen these screws, but do not remove them.
Step 2: With a screwdriver, change the notch setting on the notched plate by turning the plate counterclockwise; for every eighth of a turn, the oven temperature goes up about 25 degrees Farenheit. To turn the heat down, turn the plate clockwise.
Some thermostats can be adjusted by turning a screw inside the control knob shaft housing. To do so, remove the knob and insert a screwdriver into the shaft so that the screwdriver blade engages a screw slot. Turn the screwdriver counterclockwise about one-eighth of a turn to raise the heat about
25 degrees Farenheit. Here's how to test a malfunctioning thermostat:
Step 1: Test the thermostat with a VOM (multimeter) set to the RX1 scale. The thermostat is located directly on the back of the control knob that regulates the heat. To gain access to the thermostat, remove the back service panel to the control panel.
Step 2: Disconnect one electrical lead wire from a terminal of the thermostat and clip one probe of the VOM to each thermostat terminal. If the thermostat is in working order, the meter will register zero. If the needle jumps to a higher reading, the thermostat is faulty and should be replaced.
Step 3: If necessary, replace the thermostat with a new one of the same type.
If you need to replace the thermostat, follow these guidlines:
Step 1: Disconnect the terminal wires to the thermostat and pull off the control knob.
Step 2: Remove the retaining screws. On some ranges, there is a wire running from the thermostat into the oven. This wire operates a sensing bulb that controls the thermostat. The sensing bulb is usually held by a bracket; unscrew this bracket to remove the bulb. Then carefully slip out the wire, the bulb, and the thermostat.
Step 3: Install the new thermostat using a reverse procedure.
Nov 07, 2008 | Zanussi TC7114W Electric Dryer
Leaking washing machine
During fill only
All the time
During fill only
All the time
Nov 02, 2008 | Frigidaire FGX831CS Top Load Stacked...
My bosh is leaking
During fill only
All the time
During fill only
All the time
Oct 31, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Zanussi wjs1265w washer/dryer
hi The door of the dryer is sealed with one or more gaskets to keep the hot air in the dryer from escaping and prevent the cool air in the laundry area from being sucked into the dryer. A deteriorated or damaged gasket greatly lowers the efficiency of the dryer. To check the gasket, hold a sheet of tissue paper near the rim of the door while the machine is running. If the door leaks, the paper will flutter. If the gasket or seal leaks, looks worn or warped, has chunks of material missing, or feels hard and nonresilient, it should be replaced with a new gasket of the same type.
Oct 25, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zwf 1437w washing machine
During fill only
All the time
During fill only
All the time
Oct 09, 2008 | Zanussi ZWF1640 Front Load Washer
My washing machine is not working properly!
During fill only
All the time
During fill only
All the time
Jun 02, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Zanussi FX 1265 W washing machine
You can seal the cap by some tape, but it is better to get a good replacement, for the filter needs periodic maintenance. Your machine will not drain well if the filter is clogged.
Nov 09, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
E20 message
Hi Helenw,
The error message E20, simply means the filter plastic cage which is located behind the trap door bottom right side of the machine is full and needs to be cleaned out.
All the fibres and lint gets trapped in here and prevents the waste water from escaping, hence Error code E20.
Regards,
David
Sep 12, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
