Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Top Loading whirlpool washing machine.
Hi - The washing fills... the pump seems to be working to drain the machine... however... it is no longer spinning to shake all the water off the clothes.
Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
Mine just went bad this week. Bought the part for $25...
Posted on Sep 30, 2008
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but doesn't drain or spin
heatman101
Sep 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our washer filled with water and will not drain. There is no action at all. Water just sitting in washer. Washer will not work Help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 10, 2010 | Whirlpool LSR6332K Top Load Washer
Whirlpool top loading washing mchine will not drain
If you can get any panel off of the dryer you will see a leather or rubber joint that connects to the pump. Sometimes the socks that go missing float over the top of the drum inside the washer and get caught in the pump. If the pump joint is not broken you should see it bound up or kinked. Depending on your washer you may be able to remove the drain tube and fish out the blockage.
May 27, 2009 | Frigidaire FWSB5700DS Top Load Washer
I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Apr 05, 2008 | Washing Machines
Washer machine drains while filling
If the pump is actually coming on at all times, then I imagine this machine has a completely electronic control system ? - i.e. No mechanical timer ? - If this is the case, then the switch that controls the pump is an electronic solid-state device, or, more rarely, a relay on the board. Looks like you'll need a new power board.
Sep 15, 2007 | Washing Machines
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
