Hi... I got a vaio 8gb usb flash from a friend. My computer seen to recognise it but every time I try to open it I get the mesage "Please insert disk" It had no problems when used by my friend! What should i do to solve this?
have you tried to reformat the flash drive? go to my computer right click on your 8GB USB drive and select format, this should give you a real clean start.
Have you installed a scanner/another external USB drive since first trying your Flash drive? If so, try unplugging that and re-insert your Flash drive. I had this problem and a friend suggested this and it worked!
You use it like a floppy disk, you can copy files to and from your computer to the flash drive,then take the flash drive out and the put into another computer to share, ie. to download and copy files to from other computers such as a friend's computer. The files can be anything, music, photos etc.
Go to my computer and open it, and you should see the Flash Drive. Right click on it, and from the dropdown menu select format.. (It will be FAT 32)
As I am not familiar with your exact make of drive, check that IF it has a tiny slide protect switch on the side. If it has, try formatting it, if it won't, push the switch forward or back and it shouild then format.
As you do not give details of your computer, I cannot give further instruction for a your O/s. If it's XP the drive should be recognised automatically, but if its Win98, it will need you to install the driver you got with it on the CD supplied.
insert the flash drive into your computer and wait for it to be recognised by windows. Once it has been recognised and installed it will tell you that it is installed and ready to use.
The just go to wherever it is on your computer that you have your photos stored, select your photos right click and click on copy, then go to 'my comptuer' and double click on your flash drive to open it and paste your picture there.
Or select your photos, right click, select sent to:- and send to your flash drive, it may be recognised as removable storage.
