Question about American Standard 0356.041.020 Lucerne Wall-Mount Sink
How to install a sink
I need some instructions on how to install a sink in my new house
    Novelist:
  • 171 Answers
Hi huc0,
I'm Harvey the Master Plumber.
Your problem is: You need some instructions on how to install a sink in your new house
We could set up an on line chat right here at a convenient time for both of us. I can talk you through it. It would be helpfull if you had the ability to take pictures and up load them at that time so I can see what you've got. The only sink I don't recomend for homeowner installation is a pedistal sink. They are very difficult even for a plumber.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
Brand new house. I put laminated vinyle in the basment . Do i have to put my bathroom sink (cabinet) over the floor or put the sink firt right on the concrete floor and go aroud with the laminated
It is always recommended that you install flooring under all devices. This is so that if you ever decide to update the sink base that you won't have issues with the flooring not covering entirely. But there is no NEED to do so.
Jul 12, 2016 | Building Materials
Low water pressure at sink following reinstallation
if low pressure is only on the dishwasher and not sink.check both hoses going to dishwasher for clogs,rubber washer out of line or debris .if low pressure is only at sink ..you could also remove faucet filter ring at tip for sediment or debris .or lastly check valve under sink cabinet that feeds both sink and dishwasher
Dec 15, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
What would cause a gurgling sound at the kitchen sink when no water is running anywhere in the house?
the waste disposal system for your house was installed by a person who was not competent to do the job and didn't make allowances for sufficient air pipes in the system or placed them on the wrong side of the traps
I would have an engineer inspect the installation to pin point the problem so that what you have doesn't occur and if it is installed contrary to plan and engineering requirements seek legal redress from the plumber that did the job
Nov 15, 2015 | Dishwashers
Don't understand the incomprehensible door and general installation instructions for the aqua star. Just uses pictures, anywhere available that uses WORDS?
  • 1 what you'll need
    Electric drill and hole cutting bit
    Screwdrivers
    Pliers
    Adjustable wrench
    Level
    Teflon pipe tape
    Drain pipe for dishwasher
    Dishwasher connection kit - available at your home store (should contain water supply line for dishwasher as well as necessary connectors and compression couplers).
    New dishwasher
  • 2Determine that you have access to the hot water supply line, the drainpipe and an electrical connection under the sink. Installing the dishwasher will require extending the hot water supply line to the dishwasher, connecting the dishwasher drain to the drainpipe under the sink, and plugging the dishwasher in. If your home was not plumbed in anticipation of a dishwasher, you will need to change some fittings under the sink to make these connections possible. (See below)
  • 3Read the instruction manual that comes with your new dishwasher. Installing a dishwasher is straightforward but you want to be sure you understand and are comfortable with the necessary steps.
  • 4
  • Thanks for using fixya.
  • Jul 19, 2011 | Bosch Dishwashers
    Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
    The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
    Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
    There were no instructions to install my undermount sink. What can I do?
    Most under mount sinks are installed before the counter tops go in, they are cut to fit and glued in with 2 part epoxys and secured with screws and clamps. Replacing one in an existing counter top is not an easy job. If you have a granite top, forget it. If it is wood and formica, ok, you can pull the splash off and remove the top, but it is a lot of work. You would be better off with a new top, or a new sink, rim type. Now if you are building a new house and this is new construction, then you can do it no problem. And depending on what kind of top it is, it needs to be screwed and glued. The guy here that did granite for us, would drill out little holes, about 1/4 inch dia, and 1/2 deep for these little machine inserts to go into. Epoxy them in, then clamp the sink down or up to the top with machine screws, about 10/24, 1/2 inch long. Through a clamp, and epoxy the top on, sometimes he used clear silicone. depended on the top. If it was wood, you would just screw into the wood with 1/2 inch pan heads. Hope this helps.
    May 15, 2010 | Franke 34" Undermount Double Bowl...
    I am opening a pet grooming shop in a building that was a beauty salon. It has two washing sinks. I want to take out both sinks, cap off one and install a tub where the other one is. What do I need to cap...
    remove all plumbing that will be in the way of the new tub/sink
    install new PCV plumbing and no cap will be needed
    Kits are sold for sinks AND HAVE INSTRUCTIONS WITH THEN TO HELP OUT
    Mar 11, 2010 | Plumbing
    Need help Have new house with 2 handle delta faucets, everything worked fine yesterday till I shut water off to install hot water heater now 2 different sinks have no flow hot or cold. Checked lines down...
    Try opening all of your faucets in the house including the two that don't work. then go around the house and shut off one faucet at a time. Sometimes the air that gets trapped in a system will do weird things. I had a similar experience and finally the faucet started sputtering and then full water flow... still can't figure it out.
    Mar 07, 2010 | Delta 3555RB-216RB Victorian Double-Handle...
    No installation instructions for vessel sink
    Usually silicone caulking used as an adhesive is used
    May 01, 2009 | Home
    Installing TL794DD bathroom faucet
    All faucets install easily if you have the proper tools. Answer these questions first: 1. how many holes are their in the surface of your sink? Is there a faucet installed now? If yes, you may only need to remove that faucet and use the same feed lines under the sink to hook up the new one. Take your faucet to the hardware store and ask the plumbing clerk if the hook ups under the sink are different from what your new faucet appears to be compatible with. good luck
    Jan 17, 2009 | Toto Clayton W/S BATH Faucet BRUSHED...
    American Standard 0356.041.020 Lucerne Wall-Mount Sink  Logo
    195 people viewed this question
    Top American Standard Home Experts
    Donni Steen
    Mike
    john h
    Are you an American Standard Home Expert? Answer questions, earn points and help others
