Question about Konica Minolta DiMAGE E50 Digital Camera
Konica Minolta DiMage E40
My E40 will not take a memory card greater than 512 MB which is unavailable
Can this be fixed with a download?
  • 188 Answers
SOURCE: sd card can not be used
mostly due to continious insertion and removal of the sd card the card port in the camera gets damaged, and stops working. the camera needs repairs
Posted on Jan 24, 2008
  • 17 Answers
SOURCE: Konica Minolta DiMAGE Z6
I have used a 4GB card, but sometimes unable to read it direct from a card reader. This maybe my card reader limititions, but if i connected a USB cble to the camera, i could access pictures without a problem. Hope that helps.
Posted on Aug 07, 2008
SOURCE: KONICA MINOLTA DiMAGE 7i COMPATIBLE COMPACT FLASH CARD
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Posted on Oct 04, 2008
  • 13433 Answers
SOURCE: i cannot get my konica
Hi
the following memory types are supported byt your camera
SD (Secure Digital) Memory Card / MultiMediaCard (MMC) / Memory Stick / Memory Stick Pro
Do you have a card reader on your computer? We could format the card on the computer and then see if it works with the camera.
Can you tell me the size of the sdcard?
To format the card on your computer plug it into the reader, open my computer and find the card from there, ones you have found the right one from my computer right click and select format, Try formating the memory card to fat 12 or 16 and then when the format is complete insert it into your camera again.
(turn off the camera, insert the card, turn the camera on)
If the memory card still doesn't work plug it to the computer again and this time format it to fat32.
If this ia new sd card with alot of storage do you have a smaller card that already works on the camera?
Posted on Apr 13, 2009
SOURCE: Konica Minolta DiMAGE Z10 no sound?
because this particular model of the Z series does not have a mic. recording. kind of a waste but if you went to another model (I.E.. Z2) it does have the mic. to record. sorry but i went through the same issue myself. good luck
Posted on Aug 05, 2009
Konica minolta dimage z3 4mp digital camera firmware 1.3u can't find the software to download
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Sep 04, 2012 | Konica Minolta DiMAGE Z3 Digital Camera
I have a Konica minolta with 512 MB memory.How much more memory of SDhc/SD card can it use as it is unable to use 4GB SDHC card. Thanks.
The Z1 uses SD cards, which top out at 2GB. SDHC cards do not work with this camera, as you've already found out.
Aug 27, 2011 | Konica Minolta DiMAGE Z1 Digital Camera
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 | Cameras
I have a Konica Minolta Dimage A200. The memory
I can be fixed, but will be expensive. Get a local quote.
Mar 24, 2010 | Konica Minolta DiMAGE A200 Digital Camera
My Konica Minolta Dimage A200 do no recognize the memory cards. Can anybody help e to solve this problem?
Format the cards in the camera. Make sure you download any pictures that might be on the cards first. Use a card reader if necessary.
Oct 12, 2009 | Konica Minolta DiMAGE A200 Digital Camera
Z3 will not accept a 2g card
The Dimage Z3 accept SD cards up to 1GB (Minolta says 512 Mb, and sold it with 16Mb). This camera is 4MP , and uses less memory on card, therefore a 512MB card will be enough for it.
SanDisk Flash memory card - 512 MB SD Memory ...
from $13 - 20 stores
PNY Flash memory card - 512 MB SD Memory Card ...
from $3 - 2 stores
SanDisk SD Industrial Flash memory card - 512 ... from $14
Here 1 Gb, try at your risk, but they normally work:
1GB micro SD memory card for Konica Minolta ...
£6.90 - www.mobile-laden.co.uk
1GB Flash Memory Upgrade Card for Konica ... £3.44 - Memory Express
Here review: Steves Digicams - Minolta DiMAGE Z3 -
Mar 31, 2009 | Konica Minolta DiMAGE Z3 Digital Camera
Advent camera battery charger
ADVENT:
ADV1172E
BENQ: BENQ:
PREMIER: PREMIER:
ROLLEI: ROLLEI:
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
How to use a minolta dimage g500 camera
Do you mean the memory card in your camera or do you mean another device?
First check that your memory card works in another device. There is a lock button on the SD card that needs to be unlocked.
Second, check that your camera settings have the SD card option selected. You can select the destination of your images.
Nov 03, 2007 | Konica Minolta DiMAGE G500 Digital Camera
What kind of storage media is supported for DiMAGE 5?
MINOLTA, RM series Type I, 4/8/16/32 MB; Type I, 8/16/32/48/64/80/128/160/192 MB; SanDisk, SDCFB series, Type II, 256/300 MB; 4x USB series, Type I, 8 MB; 8x USB series, Type I, 16/32/48/64/80/128 MB; 10x USB series , Type I, 160 MB; Lexar Media 12x USB series, Type I, 256/320 MB; IBM, Microdrive, Type II, 170/340/512 MB , 1GB
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
What SD Memory Cards or Multimedia Cards are compatible with DiMAGE Z3?
The following cards have been fully tested. SD Memory card: Panasonic, Toshiba, Sandisk MultiMedia Card: Sandisk, Hitachi For more information about the latest compatibility, please refer to Konica Minolta web site.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
Konica Minolta DiMAGE E50 Digital Camera Logo
119 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
