Question about Maytag Atlantis MAV6000 Top Load Washer
Does not agitate or spin - fills and drains - checked belt & pulleys seems fine
Drive pulley cams up and down fine
thinking transmission is bad
  • 1 more comment
  • diemundave67 Sep 28, 2008
    no the machine acts like it is going thru the motions (belt spinning, etc...) if I lift the lid during operations it all stops - it goes thru complete cycle including draining - with lid up everything stops except for fill
    took out timer/control board and it looks like one of the contacts shorted with another somehow - I will try to find the part tomorrow but it looks like it is the culprit and makes sense - thanks for the help
  • diemundave67 Sep 29, 2008
    It is actually the timer. You could call it a control board since as it turns switches inside turn on/off all the different processes during the wash cycle. It was one of those switches that shorted somehow with another. Hopefully I can get another one for around a hundred bucks. The place I go to now gives you a lifetime replacement on the parts it sells that is part of the price. This has happened one time before a few years back. Other than that it has been pretty reliable. I think I will give it one more chance before I get a new one. Thanks again for the help and information.
I hear you now,
It goes thru complete cycle including draining - with lid up everything stops except,
for fill.
Now this sounds like a control board malfunction!
That will need service to test this diagnoses!
Huuum
Posted on Sep 28, 2008
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
The washer is equipped with a lid switch failure detector. If the lid switch
should malfunction, the detector will stop operations for your safety.
Read below
First,turn the control dial to proper cycle and pull dial out to start the washer. If
equipped with buttons, be sure they are fully depressed.
Close lid and pull dial out to start the washer. For your safety, washer will
not agitate or spin unless the lid is closed.
should malfunction, the detector will stop operations for your safety. Call for
service.
Pauses are normal. Wait and see if the washer will start again.
Please remember to leave a rating before you go!
Thank you
  • Neil Golan
    Neil Golan Sep 29, 2008
    Well,
    You know if there was a short on the control board it may have fried the control board!
    You may find your self changing parts till you end up spending to much money.
    How old is the washer?
    And how much have you spent on it so far in repairs before you buy this part?
    Here is an interesting report I just read!
    Repair or replace?
    When to pull the plug on your old washer
    Typically, you'll also find a troubleshooting section for more-serious problems
    in the owner's manual.
    Should you pay for a repair or buy a new model?
    The answer depends mostly on the age of your washer,
    how much you bought it for,and the cost of the repair.
    Follow these guidelines:
    When a repair makes sense.
    If your washer is under warranty or less than four years old ,
    paying for a repair makes sense.
    Note that washers under warranty might require service from a factory-authorized technician;
    readers have found them on a par with independent repairers.
    When a repair might be a wise choice.
    If your washer is out of warranty and is four to seven years old,
    it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
    But you might want to buy a new model even at this stage,
    given that today's models have added features.
    Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
    are 43 percent more efficient than conventional models built before 2001 and 56 percent
    more efficient than those built before 1993.
    When it pays to replace.
    The repair costs more than half the price of a comparable new washer.
    Data also shows that it doesn't pay to fix a less-expensive washer
    eight or more years old.
    Thanks to better recycling programs, less than 10 percent
    of washers you replace are likely to end up in a landfill.
    Thanks for giving me the opportunity to help!
    Please do not for get to give a rating before you sign off!
    Thank You, HUUUM
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
GE Prodigy Washer: Doesnt agitate or spin. Fills ...
Hello, If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Thanks
May 19, 2010 | Washing Machines
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
No spin - agitate
You just do this
  • Inspect the drover belt (belt drive only)
  • Test the motor
  • Inspect the Agitator
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Does not agitate
Agitation is the most complex operation in any washing machine. There are several components working together to make it agitate and as a result it is a challenge to isolate the problem or problems involved. Here is what to look for:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 31, 2009 | Washing Machines
Washer fills no agitation spin cycle ok
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 07, 2009 | Washing Machines
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Washing Machine Shaft Wont Move
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 08, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Washing machine will not spin or agitate.
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Nov 30, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Could I please get a follow-up to this previous issue? I just had one more question, posted on the 30th of October. Thank you!
ok i might have to put this in a 2 part solution it might not be big enough to fit here
i hope this helped you in your washer it still is cheaper to repair than to replace
your washer blew out its thrust bearing which is called the brake
while you have the washer open grease the bearings and oil the motor you can get these same things and intstructions for this to do
this is the thrust bearing kit which you will need the instructions i will post the link and a copy of the pic
http://www.appliancepartspros.com/part_details.aspx?part_id=3728465&pn_=12500036
this is the link to the thrust bearing kit you need to replace to run dryer correctly
5953465.jpg http://www.applianceaid.com/images/thrust_kit_remove.jpgthis are the instructions for thrust kit
Nov 01, 2007 | Whirlpool LTE5243D Top Load Stacked...
Maytag Atlantis MAV6000 Top Load Washer Logo
234 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
