Question about Biostar M7VKG Motherboard
Biostar 770 A+ motherboard problem.
I've bought the above board yesterday, and when i hooked everything up, the two little leds aren't lighting. in the manual i got with the board it says when both leds are off it means it's a chipset problem, or a cpu problem. I'm using the AMD Athlon 64 X2 dual-core processor, a gig of ram and club3d nvidia geforce 9600gt overclocked edition. i tried removing the ram, graphics and all, i've tried reinserting the processor but nothing helps...do i have to get rid of the motherboard and get a new one? help!
  • 33 Answers
Hello!
Sounds like your motherboard isn't getting power...
I suggest you check that you have both the 24pin ATX connector (upper center) and the 4 pin P4 (upper right) connected. If your PSU does not have a 24pin but only 20pin connector I suggest you find a proper PSU and test with that.
It's very unlikely for a new motherboard and/or CPU to be not functioning.
Hope this helps!
Posted on Oct 02, 2008
Red light on motherboard
check mobo manual and/or manufacturer support website for the exact meaning of this blinking light !!! Then proceed with faulty (or mismatched) component (mobo, cpu, mem ??? )
Feb 13, 2014 | Intel DQ57TM Executive Series Motherboard
Biostar g41 m7 wont power up after installing cpu
have you an ATX/BTX PSU?
with 24pins ATX + 4pins P4 connector?
if you haven't that it's normal that's don't work
else your PSU 5Vsb or/and your motherboard are dead
Nov 19, 2012 | Biostar G41-M7 Motherboard - Socket 775,...
HOW TO CONNECT POWER LED HDD LED RESET SW POWER SW IN BIOSTAR AMD N68S+ MOTHERBOARD
You can find the manual here: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#dl The board is usually marked, also, although it is very tough to read the small print.
Oct 31, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
I have bought 2 Biostar N68S motherboards for HTPC builds. Both of them have the same CPU and RAM. Neither of them will show any VGA output, despite being hooked up to different screens. The other...
The motherboard has a AM2+/AM3 socket, and the processor is AM2, while there is some compatibility between AM2+ and AM2 sockets, it is not guaranteed, so this could very likely be your issue.
Jul 23, 2011 | Biostar N68S NVIDIA MCP68S Socket AM2+/AM2...
I just bought a new Biostar motherboard. I hooked everything up correctly. But i get no VGA signal.
make sure the ram is properly installed just remove all the drive connection and remove also the ram and check it give the beeps if it gives the beep that means board is ok but something is wrong with motherboard try to swap you power supply also and check the power connector like 4 pin connector is also connected .try with resetting the bios also.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | Biostar P4M900-M4 Motherboard
I cant see where my power ,led,usb >>>etc wires where can i find an image that will show where my wires go ?
provided in ur main/mother board manual..
or can refer: ftp://ftp.biostar-usa.com/manuals/P4M80-M7/P4M80-M7manual.pdf or http://www.retrevo.com/support/Biostar-P4M80-M7-manual/id/23274ci668/t/2/
always do under professional supervision..(all led/light emitting diode will not function if reversely/wrongly connected)..
contact ur system admin/vendor....
Oct 28, 2009 | Biostar P4M80-M7 Motherboard
Dont know where to hook up the power and leads on the p4m80 -m4 to get power
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
Jun 29, 2009 | Biostar P4M80-M4 Motherboard
I just bought a new motherboard and managed to swap everything....except the power switch cable
whew..that's not as simple as it looks. You'll need a pin out configuration guide, if one exists, or you'll need to make one. The power interface from front panel, is usually unique to each Dell, so its' not likely to swap over.
got backup for that Dell?
Feb 17, 2008 | Dell Dimension 3000 PC Desktop
Biostar M7VKG Motherboard Logo
90 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
