Question about Optoma Projector Lamp for EP771, TX771, DX607
Ep 771 optoma projector shuts off after a couple of minutes
Our projector is shut off at church this morning after a couple of minutes.
  • Anonymous Dec 11, 2008
    Before it was even used, the projector shut off.
5 Suggested Answers
dgostl
  • 5 Answers
SOURCE: optoma EP 738
Also make sure the bulb replacement cover is on, cause there is a little switch that cuts power if the cover is off.
Posted on Sep 21, 2008
webkruzer1
  • 17 Answers
SOURCE: My Optoma HD65 Projector stops starts working and
Possible cause is overheating.
Do you hear the fan working?
What happens when you use the lowest level light output?
Does it run longer?
Also possible cause is a faulty temp sensor.
AC wire connection may not be firmly pressed in socket.
Posted on Apr 09, 2009
SOURCE: cooling fan problem projector
I have a similar issue though mine isn't quite as extreme as yours. Got a couple things you can do.
1. clean out the projector with compressed air. You might have dust building up on components that is trapping heat.
2. Your fan might be burning out. Needs to be replaced. I'm still working on trying to figure out what tipe of fan it needs.
3. The temperature sensor might be going bad. This one is less likely and most complex to solve as it depends on how the system measures the temp. I haven't checked in detail yet.
4. Replace the whole unit or send it in for repair. Both options will be costly...
Posted on Aug 04, 2009
clifffton
SOURCE: Help needed for Optoma EP 719 DLP PROJECTOR
It's a setting in the menu. A few minutes poking around will fix it.
Posted on May 18, 2013
My EP 758 is 4 years old and has 1500 hours on its second bulb. I use it for home use with a satellite input (dish network). It just started flickering a couple days ago. The main picture is still there...
It sounds like the projector itself has a fault. Sadly it's often uneconomic to repair budget projectors which are out of warranty when the cost of repair is compared to that of replacement. You should speak to Optoma support and see who their local agent is, and then ask for a quote.
UK support can be found here
They will usually charge a fee to have a look and then they'll offer an estimate for repair.
Feb 14, 2011 | Optoma EP758 - HDTV Compatible DLP...
Shuts off after a couple minutes
sounds like it's overheating. Clean out all the dust from it.
May 15, 2009 | Optoma H30 Multimedia Projector
Does it run longer?
Mar 01, 2009 | Optoma HD65 DLP Projector
Cooling fan problem projector
Jan 01, 2009 | Optoma H56 Multimedia Projector
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Jun 12, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP739 Projector Overheating
Set the projector to "high altitude mode." It will be noisier, but won't overheat. I wonder whether using one of those $10-$20 laptop coolers underneath it might be a quieter solution.
Mar 09, 2008 | Cameras
Optoma  Projector Lamp for EP771, TX771, DX607 Logo
71 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
