Question about Sony VAIO VGN-FW145E/W Laptop
How to change
I dunno how to change the typing language on my laptop (sony vaio, FW)
i used to change by typing ALT with Shift but this way is not working on this laptop.
How will i use the @ button when i use shift and number 2 the @ button did not appear... Sony Vaio SR series
The standard keyboard language and widely used setting is "ENGLISH (US)"
Set the Keyboard layout to English US so that you have standard keys for symbols etc. like @ sign with SHIFT+2 etc.
The keyboard layout / Language of your PC may have been different (other than English US), so follow these steps to select the International keyboard layout:
- Go to Control Panel - Regional and Language settings
- On the Keyboards and Language tab, click Change keyboards.
- Click Add.
- Expand the language that you want. For example, English (United States).
- Expand Keyboard list, select the United States-International check box, and then click OK.
- In the Default input language list, click Language name - United States-International (where Language name is the language that you selected in step 4), and then click OK two times.
- In the Regional and Language Options dialog box, click OK.
The above steps would change the Keyboard Layout settings to 'English US' and you would be able to type @ sign with SHIFT+2
Hope it helps! Good Luck!
CreativeTECH
May 25, 2011 | Sony VAIO SR Series Titanium Grey Notebook...
Every time i type e it comes out et
Press SHIFT then CTRL once.
Now try typing and see if it works properly.
If not then press SHIFT then ALT once.
Try typing again and see if that works.
Good luck.
Feb 20, 2011 | Sony VAIO VGP-WKB1 Keyboard
How to use Alt Car key?
I am guessing the Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. On these models, it seems the alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Aug 13, 2010 | Sony VAIO VGN-FS640W Notebook
Language settings
  • Hi, to change the "Language" back to any language of choice, do the following; from the "Desktop Screen" click on the [Start] button, next in the "Start Search" window, type: language. This will take you to the { Region and Language Options} window, now you be able to change the Language back. "Rating the help, is a way of letting me know that you have solved the problem, thanks."
Jun 27, 2010 | Sony VAIO VGN-NS140E/S Notebook PC
I cant login because i typed the password in english and the language changed into arabic
Hi James,
Just get the Alt Key Codes of your password and use to enter your english password and ola... you're in!
Enjoy!
Wrenzy
Feb 17, 2010 | Acer Aspire One PC Notebook
Power socket is loose
dc jack socket for Sony VAIO VGN-FW is very easy to loose, I think you can replace the cabled dc jack, no solder work, plug in and work, see this reference page: http://www.lapdiy.com/sony-vaio-vgnfw-series-power-jack-port-connector-dc-in-cable-p-2647.html
the above item is with ground cable, it is known that sony FW uses both harnesses with or without ground cable, you can cut the ground cable directly if your laptop does not use it, or order from this page for the one without ground cable: http://www.lapdiy.com/sony-vaio-07300012492a-power-jack-port-connector-dc-in-cable-p-2782.html
hope this can help you
Feb 04, 2010 | Sony VAIO FW Series VGNFW275JH
Power socket for sony vaio is broken how do I
On a Sony, many times the power socket is a separate piece that can be replaced. Unlike many laptop motherboards, these power sockets are a separate item the plug into the motherboard. \
Bad news is you have to dissassemble the computer to get at it.
Dec 22, 2009 | Sony VAIO FW Series VGNFW275JH
How do I use the "AltCar" on my labtop?
Okay, I know this is an old question but when i searched for the same problem recently, it was the nearest I could find. So in case others are having the same problem:
The Vaio you have is a Canadian model, which has alternate keyboard drivers for English and French. The alt car key only works with the French keyboard (durr). To switch, press the LEFT control key and RIGHT shift key at the same time, then release. Now if you use the alt car key like the shift key, i.e. hold it down then press another key, you should be able to access the pink characters. To return to English keyboard, press left-ctrl and right-shift together again.
hth!
Dec 19, 2008 | Sony VAIO VGN-FS640W Notebook
Sony VAIO VGN-FW145E/W Laptop Logo
63 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
