Question about Stanley Bostitch BT200K
Stanley Bostitch n59fn
My gun will work fine with 1.5' nails, but when I try and put 2' nail in they get stuck, about 1/2' before the plunger. what can I do to fix this
  • Anonymous Mar 21, 2014
    nail gun above brand new not firing after jamming on first use
    Problem Solver:
  • 10 Answers
Very nice tool indeed. I have had mine since they first released it to the public but I have never had any problems with either size brads. Have you ever dropped the fastener? Check your rail for bends as it may cause the longer brads to be binding. If there are no bends, detach the rail and look to see if there is debris within the rail preventing a 2" length from advancing that would not otherwise affect the 1.5". If none of this seems to be the problem, return the brads to the store for replacement as the defect may be within the brads themself. Hope this is helpful.
Posted on Nov 05, 2008
My bostitch bt1855 nail gun worked fine, until it started to dry fire 2inch nails. No problem with firing quarter inch nails. Any ideas?
Have you serviced it recently? and is the gas in date? The pistons do dry out and have to be oiled with special oil.
Dec 24, 2012 | Stanley Bostitch Nail Gun
What degree nails are used in stanley bostitch n60fn nail gun
I've repaired many nail guns and I can tell you the Stanley Bostitch N60FN uses 15 guage nails from 1 1/4" to 2 1/2" long in the FN1500 series of Bostitch nails. Nowhere does SB or any of their aftermarket dealers list what the angle of the nails is. I do know most of the SB nail guns that come through for repairs are because of damage to them from using other than SB series nails.
Oct 01, 2012 | Stanley Bostitch Nail Gun
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
Roofing nail gun will fire but the plunger only goes out about 1/4 inch, just enough to push the nail a little. plunger stays in that position unless you touch it lightly, then it retracks.
look for a jammed nail in the nose area, UNPLUG AIR FIRST. look for a bent driver and lastly when was the last time tool was serviced, you possibly have a dry o ring. Let me know
Sep 12, 2010 | Stanley Bostitch BT200K
How do you close the magazine on a bostitch sx150
once the nails are in place, slide the slide forward and you may have to press in the same button you use to open the magazine to get it closed the rest of the way.
Dec 05, 2009 | Stanley Factory Reconditioned Bostitch...
My bostitch rn46 seems to double or triple shoot nails frequently. Am I not using the tool properly or could there be a mechanical problem with the tool?
if u are right nails for gun,then make sure when u put coil in and feed in front of firing pin the nails are straight with pin and connecting wires are not bent causing nails to fall out of alingnment.
Oct 02, 2009 | Stanley Factory Reconditioned Bostitch...
Stanley Bostitch Coil Framing nailer blows head off of nail?
Make sure that when you run with one gun that your psi is between 90-110. You may need a kit. Is it an RN45 or 46? Go to Stanley Bostitch online and look up parts and schematics. Kits should only be about 15-20 dollars, easy to put in, and come with instructions. Lemme know. Please rate me
May 31, 2009 | Stanley Bostitch Coil Framing Nailer
Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
May 20, 2009 | Stanley Bostitch BT200K
Stanley Bostitch BT200K Logo
493 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
