When inserting disk into machine,machine takes disk inside,then starts spinning,as if loading something after about 3/4 of a minute,the machine comes up with "(disk not reconized, and "(no disk found)",I have tried all disks that used to work fine and tried new ones as well,they all fail to be read.
SOURCE: Toshiba SD-43HK Discs failing to load.
Sorry not a solution but experienced the same problem. The problem started off the same as you described by now my player won't play DVDs at all. Seems that the laser is faulty and it is cost prohibitive to repair (it's sold as a complete module which would be around £100). I've been advised to replace it :-(
SOURCE: Trouble with the disk tray
had the same prob with a sony dav dz it kept saying locked but after hours and hours of pressing random combinations it came off im sure it was unplug plugback in then hold power and open tray and tap stop or a combination of those buttons.i woud try it again on mine to make sure but i do not want to lock it again.
SOURCE: DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
SOURCE: Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
