Question about Price Pfister 18 Series Polished Chrome Waste Overflow Drain with Brass Tur
How to install the chtime wate overflow drain?
Hi huc0,
I'm Harvey the Master Plumber.
Your question is: How to install the chtime wate overflow drain?
For me it's just a mater of looking carefully at the old one and duplicating it with new. If you start this and can't finish it you'll be without the use of this fixture til you can. It's not as easy as it looks. It can be very dificult to work under the tub from the access or from underneath. You may also need some special tools. For instance a sawzall, a tub shoe tool, a 12' channel locks etc. It's not the type of repair I recomend to the average homeowner. You might consider the Repair Directory for a reparman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 03, 2008
Where is the drain on a crosley air conditioner?
Since the water runs down the evaporator coils its located at the lowest part of the unit. either in the center underneath it, or at the rear edge. The drain does get plugged up and the evap coils get dirty as well. When its installed in the window it should be installed so its tipped slightly backwards so if the pan get full of wate, the overflow will run out the back and not into the house.
Aug 28, 2014 | Crosley Heating & Cooling
Ge_wdsr2080d5ww started leaking when I attempted to wash a load of laundry.
It is possible that the water has leaked due to overflow as the wate level had exceeded or there was leak from the seal. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
Jul 05, 2012 | GE WDSR2080D Top Load Washer
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Eljer garden garden tub drain
Tub overflows are not required in all states but I highly recommend drilling the hole and installing the proper waste and overflow drain I recommend the Gerber brand and also when you set the tub you need to set it in a light concrete for stability I use great stuff foam for setting tubs 2 cans spray on floor and set and level tub tub will never wobble or move
Nov 08, 2009 | Plumbing
Good morning! My Kohler tub drain (original equipment - about 40 years) is beginning to shred itself. It appears to be a K-7145 or related popup drain. I've been pulling the screws out of the overflow and...
I can't really put my finger on the cause, but am quite familar with screws not wating to come out of the overflow.
When you finally do get the screws out, see if you can find suitable replacement stainless steel screws.
Get some "copper rich" antisieze from a plumbing shop or auto supply store and apply a little to the threads when you reinstall them (hopefully new screws).
After 40 years, a new tub drain may also be in order, but depending on the location, that can involve a great deal of work.
Best of luck to you!
Oct 27, 2009 | Kohler Plumbing
Freezer will not evaporate wate, so bottom accumulates an inch of ice and the starts overflowing out
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 08, 2009 | Refrigerators
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For PuristĀ® Baths...
Pegasus Push Button Vessel Sink Drain with overflow
Put plumbers putty around the flange that will be in contact with the sink. When you put it into the hole, try to line up the overflow as good as possible. The nut that goes onto the bottom (tailpiece) has a rubber gasket that will go between the nut & the sink. Adding some plumbers putty here won't hurt. After all is secure, just remove the putty that squeezed out from tightening.
Feb 21, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Water leak
you ll need to reomve the front cover and see where the wate ris coming from, 2 screws hold the door on, and the 2 screws opposite to door hinge will remoive the fron t panel, you then be able to see where it sleakin, before you drop the front panel run you hand on the inside of the door ( the boot is only made of rubber ansd is possible tht it has a small rip in it allowing water ot leak out during cycle.
Apr 07, 2008 | Maytag Neptune MAH7500WH Front Load Washer
Price Pfister 18 Series Polished Chrome Waste Overflow Drain with Brass Tur Logo
121 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
