Question about HP Office Equipment & Supplies
Wrote a letter, doesn't print, thinggs aren't printing
  • 558 Answers
Since in your case it is printing some time and stop in between, find out the Paper tray setting.
Check whether any paper stuck in the roller by opening the cover.
Posted on Sep 28, 2008
Daisywheel doesn't print the correct letter when typed
Probably the print wheel homing pawl is broken you need atech.
Nov 30, 2012 | Brother SX-4000 Typewriter
How do I correct this printing problem? My colored letters on the page print. Black print doesn't print onto the paper. I have a lexmark z615 printer.
Try to clean the print cartridge nozzles. On your computer, open the Lexmark Solution Center by going to the Start menu > Programs / All Programs > Lexmark Z600 Series > click the Maintenance tab > under Select Maintenance tool, select Clean to fix horizontal streaks > click Print. The printer will then print a test page forcing ink through the cartridge nozzles and clean them.
If that doesn't help, remove the black cartridge and try to manually wipe the cartridge nozzles with a slightly moistened soft cloth to clean it from dirt and clogs. After wiping the nozzles, reinsert the cartridge into the printer. Print a document again to verify that the problem is fixed.
If the problem continues, try to insert a different known working black cartridge to identify if it's a faulty cartridge issue.
If you still need assistance, please contact Lexmark Technical Support Center.
Sep 12, 2011 | Lexmark Z615 InkJet Printer
My HP 1315v psc is only printing the first half of the sentences. the last half is missing. It prints pictures ok, but not my letter I wrote. It's like I tore the letter in half and had only the left...
Mostly pictures are in color, if your color cartridge is good it will gives you good print,if your mono cartridge clogged you wont get proper mono prints.. remove mono cartridge take ear buds dip in to the water clean nozzles gently, take print out then chem repeat two three times if result not satisfied, replace mono of luck..
Sep 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
When I push the letter "G" , for example, a
If the printwheel isn't distorted or you aren't in KBII or a language mode the printwheel homing pawl is likely broken. You need a tech.
Sep 01, 2011 | Brother GX-6750 Typewriter
Keys type incorrect letters
If you aren't in KBII, Language or PS mode the print wheel homing pawl is broken and you need a tech.
Jun 06, 2011 | Brother GX-6750 Typewriter
HP Laserjet 4Mplus won't print doc & says: PC Load Letter
Pull down front cover and Put a sheet of paper in tray 1 assembly.
Feb 20, 2009 | HP LaserJet 4 plus Printer
Hello Ncerritos. I have an ideaj that may help. First disconnect the AC power. Second disconnect the RS232 or interconnect cable to the mainframe and look for bent pins in cable or socket. If you find pins bent I worn you they are no very fexable. If it is the cable it would be safer to replace the cable, If its the socket you may try straighting CAREFULLY. I wish you luck on this ventur.
Sep 28, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Is the power coming properly, Is the printer blinking ok.
Find out the Printer is it is Set to default and not goes in offline, during spooling the print.
Let me know if you need further help
Sep 28, 2008 | Office Equipment & Supplies
27 people viewed this question
Ben Johnson
