Question about Lexmark Office Equipment & Supplies
Cover open sign shows all the time - Lexmark Office Equipment & Supplies
    President:
  • 2,072 Answers
There is an interlock switch or sensor on all the covers. You need to open the cover and look for an opening in the cover it closes against. In those openings there are normally switches that a tab turns on to let the machine know the cover is closed.
The switch may have become dislodged, or more likely, the tab on the cover that hits the switch to actuate it has broken off and is not hitting the switch giving you that message.
Posted on Sep 28, 2008
It says drum error but the cart and drum is replaced with new and still can't get past the drum error message.
Hi There!
What you can do to clear the Drum Error message is to clean the corona wire.
  • Open front cover of the machine and remove the drum & toner cartridge assembly.
  • Remove the toner from the drum and gently shake the toner cartridge from side to side put it on a piece of paper to avoid scattering the toner.
  • Theres a blue tab on the upper left side of the drum, slide it from left to right, right to left about 5-6 times don't forget to put the blue tab back to it's home position(where the arrow is).
  • Put the toner back into the drum make sure it will click into place.
  • Reinstall the drum and toner assembly back into the machine and close the front cover.
  • LCD should display the date & time.
If you continue to receive the message try resetting the drum counter by doing the following:
  • Open the front cover
  • Press the Options key on the control panel. The display will show "REPLACE DRUM - 1.YES 2.NO".
  • Press 1 to reset the drum count.
  • Close the front cover
Hope this helps!
Vikroks
Mar 23, 2011 | Brother IntelliFax-2820 Laser Fax
I change the drum for my fax machine, but it still says Toner Life End... and it is a bran new cartridge?? I tried turning it off and on, and unplugging it... but it still says Toner Life End... how do i...
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Good Luck and Thank You for using Fixya.
Jan 08, 2011 | Brother IntelliFax-2820 Laser Fax
HOW DO YOU TURN OFF DRUM LIGHT ON BROTHER 2820
Open front cover....press 'options', and select 'new drum'
Nov 11, 2009 | Brother IntelliFax-2820 Laser Fax
Can't reset "change drum soon" message Brother Fax 2820
Open the front cover and press and hold -stop,reset button
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
We are unable to load the paper on our Sharp UX-266 as the paper jam sign comes on every time we try it .
Unplug the machine open all covers and check for paper jams, remove the paper draw check for paper behind the draw. load paper before pluging in
Aug 15, 2009 | Sharp Office Equipment & Supplies
Where is the top cover switch? I can't find it.
This is the manufacter's official manual link:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_750_770_EN_85.PDF
On page 63 it shows you how to open the top cover. You must open the front cover first then open the top cover by pressing the blue levers on both sides of the top cover.
It also has a diagram.
Hope this helps!
WizardRepair
Jul 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Cover open message
Just check may bi cover is not locked properly .and also check there will bi a sensor having some bad sector .just clean it properly.or replace it MIA AKHLAQ
Dec 17, 2008 | Panasonic KX-FLB751 Plain Paper Laser Fax
OUTPUT TRAY FULL
If you open the cover,the same cover you open to replace the toner.There is a guide that can swing up and down.This sensor is situated in this guide.Swing this giude to the down possition and you will see the arm that actuate the sensor.Make sure this arm is in the correct possition and can swing up and backwards.Some time this arm get stucked against the body of the fax.It normally hapened when the upper cover of the fax was removed.
I believe you can fix this one, it is a relative easy fault
Dec 08, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
BROTHER FAX/TELEPONE T76
Unplug and plug back in see if that gets rid of the check paper pls open top cover. Also make sure the confirmation is set. Transmission report on
Oct 31, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
81 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
