Question about Milwaukee Tool Milwaukee 6125 Sander Ro 5 5.5A
Wood working sander?
What kind of sander should i use for my woodworking? Belt or disc?
I'm really confuse with it, some say use belt while the other say disc, what do you think?
it's a delicate job
  • 29 Answers
Belt because it work realy good use ing the circle scraches the wood and the beld dos not
Posted on Nov 06, 2008
What are the safety roles of the disc sanders?
its a disc sander it has no safety roles.
Apr 09, 2018 | Tools & Hardware - Others
How many Types of Power Sander?
Power sanders are really helpful tools that help the sanding job done in fewer minutes but usually takes hours by hand. The amount of effort requires while removing old peeling paint depends upon the type of sanders is used. If you pick a wrong tool, all your effort may go in vain. Different sanding machines have different specific utilities.
more details Category Sanders
Mar 14, 2018 | Tools & Hardware - Others
Where can i buy a drive belt for a clarke model bt1009a sander
from Clarke direct or 'sanderparts'.
Clarke CS4-6D Belt and Disc Sander Manual - Clarke International
https://www.clarkeservice.co.uk/manuals/woodworker/cs4-6d.pdf
Faulty goods should be returned to their place of purchase, no product can be returned to us without prior permission. This guarantee does not effect your statutory rights. IN THE BOX. The following should be supplied inside the box. If any parts are missing, please contact your local Clarke dealer. • 1 x Belt/Disc Sander.
Where can I buy a belt for a clarke model Bt1009a sander - Fixya
www.fixya.com/support/t14574446-buy_belt_clarke_model_bt1009a_sander Oct 7, 2012 - The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in. I found a replacement at sdp-si.com, part number A 6R 3-060031. Look here for timing belts (inch), then ...
Clarke Power Products BT1009A - Free Shipping on Orders Over $99 ...
https://www.summitracing.com/parts/clk-bt1009a Find Clarke Power Products BT1009A and get Free Shipping on Orders Over $99 at Summit Racing!
[PDF]CA30 20B - Clarke
https://www.clarkeus.com/~/media/NewClarke12.../PL56091130.as... Translate this page
If the batteries are incorrectly installed or inaccurately connected, the electric components of the machine may be seriously damaged. The batteries may only be installed by qualified personnel. According to the battery model number (WET or GEL) being used, set the functional circuit board and onboard charger (optional).Missing: bt1009a
Clarke Sander Parts ' Buy online at sanderparts.com
https://www.sanderparts.com/categories/Parts/Clarke/ Clarke sander parts - buy replacement parts for all models of Clarke sanders.Missing: bt1009a
clarke model bt1009a parts Google Search
Mar 12, 2018 | Sander Tools & Hardware - Others
What causes my belt sander to leave black goo on the wood? I keep replacing the sand belt, I do not push the sander into the wood.
Maybe you are burning the wood. If the wood is hard (like oak or maple) and the grit is fine (like 100 or higher) then this can only be avoided by NEVER running it still in one place. Keep the sander moving quickly over the surface. In fact, you should start the sander BEFORE you touch it to the wood, and when you do touch the wood you should be landing it like a little airplane on the runway. As long as you keep the sander oriented with the grain you can move it forward and back as well as side to side. Just keep moving until you lift it off of the wood - this also helps keep the surface flatter. Good luck.
Jul 30, 2012 | Skil 3 in. x 18 in. Belt Sander - 7500
At my work our belt sanders seem to make gauges as we bellt sand coming from the middle of the pad surface. Kind of a circular spot with long tail gauge simalar to the shape of human *****. I have worked...
i believe that is caused from to much pressure on the belt sander. Try letting the weight of the machine do the work and use smooth even passes. If you want it to cut faster try using a heaver grit, and again let the weight of the machine do the work. Hope this helps!
Mar 10, 2011 | Porter Cable Cable 363 4" x 24" 1500 SPFM...
I am sanding down oak boards that i have laminated together for a bar top. no matter what grade of belt i use or how careful i am it is leaving lots of ridges in the wood. never had this happen before
Belt sanders are not good for finish sanding because they will leave ridges, but they are great for removing lots of wood fast and getting you roughed in. Use the belt sande to get your work fairly level then switch to a palm sander to get it smoothed out.
Feb 09, 2011 | Makita 9404 4'' x 24'' Belt Sander
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Milwaukee Tool Milwaukee 6125 Sander Ro 5 5.5A Logo
128 people viewed this question
Top Milwaukee Tool Tools & Hardware - Others Experts
Bill Boyd
 perry tradesman    ...
perry tradesman ...
Level 1 Expert
Are you a Milwaukee Tool Tool and Hardware - Other Expert? Answer questions, earn points and help others
