I have a new hdtv antenna and my hdtv gets all the local channels except 8. The direction from my house is 171 and that is also channel 4. I get 4 fine but not 8. what's up?
  • kimnaragon Sep 30, 2008
    repositioning the antenna did not help, it actually hurt. all other stations come in clear as a bell. The antenna can not get any higher without the antenna falling over.
    Genius:
  • 1,250 Answers
Have you checked the band setting of your tv
Posted on Sep 30, 2008
  • 2,071 Answers
Go to Menu> Favorate channel >Antenna >and choose autoscan or search;
Hope it may help you;
Regards,
VOTIT
Posted on Sep 28, 2008
    Scholar:
  • 191 Answers
There would be weak signal reception at your antenna so it can't get the other channel. So change the antenna direction. If there's no result then increase your antennas hieght means keep your antenna at higher position.
Regards,
Laxman
What do i need to get regular channels on the tv
How to get regular TV channels?
Your HDTV should have a digital TV Tuner (ATSC) which may need an indoor antenna. Change your TV's input selector to TV or Antenna or Digital (probably one of those three) and scan for channels. If you don't get any channels, then you do need an antenna. Probably another $10.
How to get basic channels on new HDTV without cable - HDTV ...
www.tomsguide.com/forum/53920-4-basic-channels-hdtv-cable What do need to get regular channels on the tv Google Search
Dec 12, 2016 | Televison & Video
How do I get Channel 7 & Channel 8 back on my tv
Good Question but that depends on what is connected to the tv. Is there an antenna and if so are they local stations. Normally adjacent tv channel numbers are not in the same community If there is an exception they would separated by many miles. Is it the input from a cable box, if so contact the cable company assuming other channels are working. There are many possibilities, if you can go back to what it was before you lost the channels.
Nov 28, 2014 | LG 55LW5600 1080p 120Hz 3D LED TV and...
Antenna channels
use digital antenna via radioshack
Jan 24, 2014 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
I HAVE A DIGITAL ANTENNA AND I WHEN I DO A CHANNEL SCAN IT'S NOT PICKING UP ALL THE CHANNELS HOW DO I GET ALL THE CHANNELS
It has to do with the distance and direction of the different TV station antennas. You have to have a strong enough antenna, and you have to aim it at the TV station's transmitter.
Apr 19, 2010 | Memorex MLTD2622 26 in. LCD TV
I have had an outdoor antenna for several years to recieve HD local. Before the conversion I purchased a Samsun HD Tuner. It was working fine will all channels working and guide providing all program...
8 11 & 14 are std definition. All digital channels are 1.1, 1.2, 1.3, etc. You may need to re-align your antenna. Digital is Very Very direct, analog was very scattered. Hope this helps
Jul 08, 2009 | Samsung DTB-H260F
I'm able to view all local channel in digital (new tv with in philip hdtv indoor antena) but after conver to diggital I lost channel 7 and 9 I scan many time but sitll no lick
What local area are you in? 7 & 9 may have moved to another channel. Every distributor of channels ie. Comcast, Directtv, Dish, Bright House, etc has channels all over the map!! with no real clear plan it seems! If you go to DTV answers.com you can get the new local lineup for your area. At this point, if you still don't have the signal, you may need to re-align your antenna for the best possible reception. If you go to Terk.com you can type in your zipcode and it will show you where the transmitting antennas are located. You may need a better antenna like a Wineguard or larger Terk to get all your channels. Hope this helps
Jun 23, 2009 | Insignia Digital-to-Analog Converter for...
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Dish Network Channels Work but Local Television Channels Do Not
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Apr 21, 2009 | Sony KDL46S3000 46 in. LCD HDTV
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
