Question about Home
How can I unclog plumbing in whirlpool tub used to clean dogs?
Inherited a jetted tub with house purchase. Motor seems to work, but no air out of jets. My contractor found that if all jets but one turned off, air will eventually start coming and then other jets can be turned on. Yesterday we were told by neighbor that previous owners used to give their dogs whirlpool baths in the tub, which caused the plumbing to clog up. They were unable to clean the fur out.
Is there any practical way to unclog the pipes, or is the only option to replace the tub? Or is the problem more likely in the motor? (I don't want to make a decision only based on hearsay.)
This is a rural area where it is extremely unlikely to find a whirlpool tub repair person.
Thanks!
  • Anonymous Mar 25, 2014
    I have a jetta air jet tub. After a few minutes with the air jet blowing, a few of the very small air holes shoot the water out extremely hot. It doesn't happen to all the jets, only 2 or 3 of them. Is this a malfunction or can it be adjusted?
  • Anonymous Mar 28, 2014
    The tub turns on by itself. This is a basic model air jet tub with a turn on plunger switch.
    Champion:
  • 242 Answers
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Get jets unplugged
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Jan 19, 2014 | Whirlpool Home
My Royal bath tub leaves residue each time I use it. How can I stop this
US Parts Center
Oct 18, 2013 | Whirlpool 5"x36" White Bathroom Drop-in ...
We have a Kohler Purist Air Bubble Massage tub... the last couple days the dial has randomly started lighting up with the green light tracking down the middle and you can hear the motor or the jets on the...
This is sounding like a relay not working on the circuit board inside the control box. You will want to have a Kohler service center send someone out to have it checked. You most likely need a new control box.
Aug 14, 2011 | Kohler K-1110-AH-0 Purist whirlpool with...
Just bought a home with a swirl - away tub need to clean out and I am not sure how to remove the jets from the inside of the tub. I need to clean them..
Check with your local plumbing supply shop, there are special self cleaning chemicals to run thru the system, also can be purchased on line.
May 19, 2011 | Whirlpool Home
My jets aren't working. who should i call to fix? a plumber or electrician? can't seem to find a company to service my cielo by whirlpool jacuzzie tub. Txs.
If you can hear the the motor running then call the plumber....if the motor don't run then call the electrician...
Or find someone like me that does it all...:-)
heatman101
Oct 09, 2010 | Whirlpool Home
Can not get the jets to work
Most of the control buttons on a tub are not electrical. These buttons are connected to an air line that runs to the motor. Sometimes an aggressive button push can literally blow the air line right off of the bottom of the button.
This problem is as easy to fix as it sounds. Find the loose air line and push it back onto the button. You will need to open up your access panel. Bring a flashlight.
Be sure to check the connection at the motor too. Good luck
Dec 02, 2009 | Home
I have an aqualux whirlpool tub w/ cracked jet housing
yes i can do it call me 301 659 9968 rick
Oct 15, 2009 | Home
How to identify make and model of old whirlpool tub?
This is a problem common to all whirlpool/air jet style tubs. The pumps become air locked due to the water evaporating from lack of use. All tubs need, and have, SOME means of priming the pump, this is most likely what the problem was, originally, for you. This time in particular you found it to be electrical in nature but for future reference, for you and all who have these style of tubs, I am putting this out there. Some where on the tub, usually along the top edge of the tub is a vent knob that controls the amount of air that the pump is allowed to mix with the water for the jets, usually by closing this valve all the way (tub needs to be full of water of course) and running the pump for a minute or 2, you should be able to get the pump pumping water again, if not you may need to do something else with your particular set-up to get it purged of air, the pumps in jacuzzi tubs are designed to pump water, not air, so if the motor is running but you get no jet action, your most likely air locked and need to prime pump/purge air.
Sep 22, 2008 | Home
Home Logo
1,133 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
