Question about Frigidaire Refrigerators
My refridgerator keeps cycling on and off. temperature is50 degrees . where do i put r-134 in on high side at? thanks.
Frigidaire model frs26r4cq1 is4-5 years old. thanks.
Posted on Oct 01, 2008
  • 750 Answers
Hi katdaddy,
Welcome to fixya,
You said,
Your refrigerator keeps cycling on and off. temperature is50 degrees .
This means either you have a leak that must be detected befrore you re establish freon pressure or your thermostat is bad.
What is the model # and age of the refrigerator?
Posted on Sep 28, 2008
Bmw x3 fuse diagram
Did you use the proper gauges to measure the high side and low side pressures as you added the 134 (I assume not Freon)? If not, it's possible you put too much 134 on the high side and either you kicked a breaker for the pressure or you just burned up the compressor.
Apr 04, 2014 | 2004 BMW X3 2.5i
Everything in the refridgerator is frozen,
Can you hear the refrigerator cycling on and off or is it running continiously? It it is not cycling the cold control/thermostat is defective.
Oct 08, 2012 | Amana AFI2538AEB (256 cu ft) Bottom...
Refridge temp
Lets go over the way a sealed system works. There is a highj side and a low side. The low side is the side that passes through the evaporator coils inside the machine. Most times on the freezer side only, but sub zero has independent sealed systems for each side. Once it goes throug the evaporator its then condensed into a liquid state, the high side. This is also the hot side. Well, lower pressures in the low side would logically mean lower temperatures. So for the refridgerator not to freeze more freon is used on it to keep the low side pressure higher than normal, giving the cooling effect verses freezing. So, and here is the bad part, if you are seeing ice build up in the refridgerator side you have a freon leak some where allowing the pressure to be less than required to keep it above freezing. Call a service technician and depending on how the model, sub zero warranty is parts and labor covered for the first 6, and only parts from the 6-12 year.
May 27, 2012 | Sub-Zero 642
The fridge section does not appear to be keeping goods cool although temperature on front of fridge says 1 degree
Freezer fan not working or blocked by over ice formation behind the freezer. Switch of a/c for defrost. After some times, plug on . It's due to malfunction of defrost cycling. Keep thermostat at 5 degree and check thermostat, timer and defrost heater are working properly. thanks.
Jan 31, 2011 | Samsung RS2534 Side by Side Refrigerator
1999 gmc Jimmy only Blows hot air. Diverter actuator is moving and working. Even when compressor starts all pipes are hot. Check 134A and was low. When put in less than a can the compressor would cycle on...
When recharging the ac you need to recover the old refridgerent. That means you have to take out all the old 134 and replace with new 134. On the engine sticker under the hood should tell you how many pounds of 134 it takes. When put in the 134 make sure your ac is on high.
Jun 30, 2010 | Cars & Trucks
Need to recharge the ac system. I see there are two ports within the system. Which is the proper one to recharge my system? 1994 gmc sirra pickup k1500 with 350 motor
if you truck has r-12 you need to convert to r-134
if you truck has been converted to r-134 the small port on the low pressure side is the port to use..
the truck must be in a warm aera about 80 degrees
then hook up the hose or gauges on to low side
start the truck and turn the air on (putting it on high cool and high blower open the can of freon and as the compressure in the truck starts to draw the gas in rock the can from side to side .. if the gas is going in the can will get cold
Mar 01, 2010 | 1994 GMC Sierra
Our refridgerator is not getting cold! it is staying at 60 degrees.. we tried cleaning out the back fan, and also tried resetting the temperature gauge but it keeps going back to 60 degrees and it...
Please double check your model number because that number is not listed. I am pretty sure it has a dual evaporator one for freezer and other for the fresh food compartment. Check behind the cover of the fan inside the fresh food compartment to see if the coils are icing over. Send me the correct model number will help me decide if it is something different. I will even send you a Service manual with the correctmodel number, Thanks, Sea Breeze
Feb 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
Believe my compressor is bad
bite the bullet. or get a repiar person who know how to fix it.
Oct 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
190 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
