Question about Euro-Pro Steam Generator EP8001 Iron
Steam generator iron domena class 100
To muchwater comes out instead of steam
5 Suggested Answers
snakehead
  • 1070 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
snakehead
  • 1070 Answers
SOURCE: My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Manual for Euro-Pro G6118H
I don't know if you have the number for the euro pro customer service department; but, I had the same problem, called customer service, and had a manual emailed to me. The manual came within a couple of hours via email. In case you don't have the number and still need a manual for your unit, try calling 800.798.7398. I hope this helps and good luck!
Posted on Jul 18, 2008
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
I have a domena steam press and there is water coming out and soaking the clothes. Water comes out as steam but as well as this it drops out as water.
Lime scale build up inside the elementchambers causing poor heat transfer to the water the steam being cooler thAn usual condenses back into water it reaches the porthole the steam is ejected from and you get this leaking effect steam and water together your need to professionally get the device descaled
Jul 03, 2016 | Irons
My domena steam press leaves brown stains on my
You may have to use only distilled water in your iron.
Sep 14, 2014 | Irons
How can I get my Domena SP400 steam press to produce steam
Blockage " mineral deposits" get a de-scalar and follow the directions. Only use distilled water in steam iron.
Sometimes vinegar will work depending on mineral deposits causing blockage.
Apr 21, 2014 | Irons
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
Domena excellence sp400 how to change thermostat in steam press need to take a pin out to get access to elements and thermostat
You can get a manual from http://safemanuals.com/brand-user-guide-instructions-owner-manual/DOMENA, unfortunately they charge for there manuals. I believe if you where in the UK asking this question you will get an answer faster from a local dealer! Good Luck!
Nov 28, 2010 | Singer Irons
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Euro-Pro Steam Generator EP8001 Iron Logo
Top Euro-Pro Irons Experts
Gil Shultz
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
