Question about ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
E-Machine Mother Board Connections
I have a 3 yr. old E-Machine T3410. I removed apart all the components for cleaning. I thought I paid close enough attention to all of the connections to put everything back together. I thought wrong! There are 3 independant 2 pin plugs that connect to the front panel. One for the start/stop (I got that one right), the other 2 are for the LED's. Everything works fine, I would just like to have everything working...Including the lights.
Can anyone tell me where I can go to get a connection diagram, picture...Something that can show me the connections. I checked the e-machine site, and in their motherboard repl. info, it only says "pay attention to the connections"! If I had done that as well as I though I had, I wouldn't be asking for this help and info.
Any help and/or info will be greatly appreciated.
Sincerely,
TP
    Scholar:
  • 76 Answers
Find the company, and name of the board, and look that up. Computer manufacturers could use any number of different boards. You need the specific manual to that board. The manual should explain where the connections go. Sounds like you have the LED HD and POWER ON LED disconnected.
Posted on Sep 28, 2008
  • J. May Sep 29, 2008
    I believe that I found a link and the page to the manual that may help you.
    http://www.fixya.com/support/p363099-asu...
    Just orient the board with the small, obscure drawing. I believe that you will need to focus on the pins that say LED. Sometimes the wires will be labled with what they are or whether they are + or -. If yours aren't just do the best that you can. In my experience, I have never burned anything out when connecting the front controls even when I get it wrong. I have had the wires mixed up before. I am not saying that you cannot short something, but I never had. BTW, I found the manual on this website. Hopes this works.
I bought the new style batteries for my mother-in-laws older modle mini jazzy that have a 1 year guarantee and are expected to last 2 to 3 years. It's been 3 months now and I'm already having issues that...
Deborah,
The most common problem for this power chair involves the connections at the rear of the chair for the VSI controller (joystick). Unplug the large and small electrical connectors at the rear of the chair and inspect for discolored and corroded pins on the plugs. You can clean the flat pins on the large connector with a green synthetic scour pad and WD40. Spray contact electrical contact cleaner on the other pins and plugs.
Check the voltmeter on the back to make sure it is indicating charging. If not, remove the the rear cover and look for a black boot over a fuse holder. Inspect the fuse (7.5 amp ATO) to see if it is good. The on-board chargers on these chairs have a history of going bad, but are easy to replace. That being said, if you have good battery connections, good charger fuse, good cord connections, good voltage meter, then your most likely culprit is your on-board charger. The least expensive and easiest fix is to buy an off board charger and plug it in the front of the VSI (leave the old on-board one in the chair and don't plug in the AC cord).
Check the battery connections to make sure they are tight. Check the charger cord and make sure it is plugged all the way in.
If you have access to a voltmeter you can make electrical checks on all components. For now, I would check the obvious visually and mechanically. The connectors on the rear of the chair coming from the VSI are usually the source of most problems. Hope this helps.
Dec 18, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
I have a hotpoint ultima wt741 , 3yrs old , washine machine does not show door is closed , the red closed light does come on and machine will not start and warning 'door' comes up on display panel , i have...
I have this exact problem. it starts during a cycle or after and then although the door locks the light to say it is only briefly flickers on and it will not let the cycle start. I have fixed this several times but am not sure how. I replaced the part that engages the lock even though the lock works and checked the control board at the bottom to see if it had blown anything (earth or components ect) and it was ok for a week or so. It did it again, I checked the connectors again on the control board again and once again it started ok. Again it did it, this time I thought that there was nothing obvious with the control board, unless a dry solder joint which I could not see, so I just tipped the washer forward onto its front as I had been doing to get to the control board and again the washer started.
Now this washer is rubbish in my opinion with anything to do with blockages, as it used to get F error codes that I solved by cleaning the pump. now I concluded that tipping it forward could be dislodging a blockege so have just this minute decided to check the pump, even though its not a F code error, and found a ridged piece of grass stopping the ball in the black rubber going to the pump from doing its job. I have removed it so fingers crossed this is the problem and not some relay on the control board. Try tipping it forward and clean the pump out while its over, let us know on here if it solves your problem also to be conclusive this is the issue.
Sep 04, 2010 | Washing Machines
Have a 3 yr washer that at the end of the wash it stops!
Thanks for writing to Fixya.com.
This sound like a loose connection in the wiring in the machine. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards.
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
THE SCREEN SMEARS NAD SHUTS DOWN
Hi eakesj:
A number of things here should be checked.
First shut down and remove all cards, and power connections to all the drives such as cdroms, hard drives.
The power supply should also be looked at and tested for correct voltages on each wire. This can be done with a voltage meter.
Turn on the power and see if you can get the machine to start to the bios screen. (this will work if you have a video processor on board, if you have a video card, you will need it to use the monitor).
If that will not work, then you have more problems than you thought at the beginning.
If the mother board will not work at this point, then you have problems with either the mother board or the cpu processor. There is a possibility that there are problems with the memory modules.
So, if you have only one memory module, then I would remove the memory, carefully clean the contacts, (a clean pencil eraser can work, if you are careful, and do not press very hard) and then plug the memory back in and try again. Also if you have extra modules of the same type, try one for testing.
If you are still having the same problems, then the mother board or the cpu is the problem. At this point you should consider if you want to continue and repair or buy another mother board of the same size. If you buy another kind of mother board, remember you will have to re-install your operating system over the original one to get the complete setup and the bios to work correctly with it. Many times this can be done, but you risk losing data (you will lose all data in MY DOCUMENTS), and may have to completely re-install the OS. You may want to install the drive in another computer as a slave and back up any data you want to save before you proceed.
If you decide to continue with your original mother board, and still have problems, then the cpu or the mother board is suspect. To test the cpu, either test your board with another cpu which is compatible, or check the mother board with another mother board of the same exact model.
Hope you find the problem.
Feb 03, 2009 | eMachines T6534 PC Desktop
Runs intermittent faults F-70
The Duet washer is a good machine, just unfortunate Whirlpool engineers used oxidative circuit board coatings. All the circuit board connections are oxidizing causing the machines to have faulty connections. We have fixed the problem using this information.
UNPLUG the machine first . Take the top off (3 screws in the back) , remove the mother board box from the frame housing and remove the lid. Now you can see the circuit board.
Carefully remove ONLY one (clip plug-in) at a time. Scrap with a (knife or sandpaper or steel wool ) the edge connector where that plug was, on the circuit board removing the oxidated metal (it may not look oxidated but must be cleaned), Next put ( vaseline or mineral oil) on the edge connector where that plug was, NOTE: Vaseline or mineral oil is a non-conductive oil and will not effect electronic operation but will prevent further oxidation and the erratic operation of the mother board will cease.
Now do the next plug and repeat until completed.
NOTE: We recommend only one plug at a time so you do not get confused where each plug belongs.
Put the cover back on the mother board box and reattach to the frame, then put the lid back on and screw it down. End of any problems.
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine
Nov 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer broke its saying 6 f
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Emachine motherboard connections
EMachine apparently doesn't think anyone needs to know the motherboard connections! But Gateway uses the same board and here is the answer to your predicament: http://support.gateway.com/s/MOTHERBD/FIC/105554/105554tc.shtml
Good luck, Steve Medley
Sep 21, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
BOSCH DISHWASHER Loss of power
check fuse in plug top,if its not that it could be door switch 30 years repairing. Close Ire....
Feb 22, 2008 | Dishwashers
Computer turns on, but there is no display on monitor.
my goodness.. you have spent a lot in your computer i think.. i dont think changing mother board and installing a new vedio card will solve this problem.
as u have said that u have installed a new card make sure that you are giving the connections of your monitor to the gforce card and not to the mother board again.
if connection for monitor is going for gforce properly your RAM is the problem. as per your configuration its single 512mb ram. i would advice you to go and get another DDR RAM(same 512 prefrably) from any of your friend and put it in you mother board in by removing the normal RAM you had.
this will work for sure i think.
if this is not working dont rate me in-approtiate. i just triend my best. sorry and tahnks.. good luck
Dec 28, 2007 | Computers & Internet
ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard Logo
189 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
