Question about Toshiba 27A33 27" TV
Rerace lines @ top of tv Toshiba 27A33
Retrace lines @ top of video, what must I replace to solve this?
    Champion:
  • 252 Answers
Change the 100/50volts capasistor on vertical section
Posted on Oct 02, 2008
I have a toshiba 27a33 without a remote and i am unable to change the tv/video settings. is there any way i am able to change the setting manually without a remote? Thank you.
Hello
Sorry. Your TVs front panel has no menu button to press. The only way to chane it to AV/TV, cand be done with its remote control which ahs that button to press. You just buy one new remote control, of get the present one repaired. OK.
Dec 06, 2010 | Toshiba 27A33 27" TV
Tip
Toshiba 27A33 - service mode
Here is a link for entering the service mode just like they do at the dealers.
http://www.kjudd.com/tips/toshiba27a33.html
Here is the link for the owner's manual from Toshiba's American website (the Canadian site doesn't have this one available):
http://www.tacp.toshiba.com/tacpassets-images/models/27a33/docs/27a33_om_e.pdf
Hope this helps,
-canosoup
on Sep 28, 2009 | Toshiba 27A33 27" TV
Lines at top of screen, about 4"
Hi:
This is due to vertical deflecton problem, there is some capacitors that has gone bad and need replacing. It might just be one cap rated at 100uf 35 volts. This is called vertical foldover eventually the top will fold over or you will get a 4" black border on the top of the scrn.
Aug 23, 2010 | Toshiba 27A33 27" TV
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
Toshiba 27A33 horizontal lines at top of screen
the problem is in vertical section of ur tv.. a filture capacitor 100mfd 63v or 47mfd 63v must be changed in vertical section
Mar 25, 2010 | Toshiba 27A33 27" TV
Retrace lines in top of tv...
These lines are cause by defective capacitors in the vertical section of the TV. No adjustment will work unless the capacitors are replace. The values of the capacitors are between 1uF, 10uF or possibly a 47uF.
I do not have the service manual at this moment but you can google it by the model number of your TV.
Let me know if you need further assistance.
Jun 16, 2009 | Toshiba 27A45 27" TV
Audio trouble with my tv
use your remote . manually fine tune your tv.
May 05, 2008 | Toshiba 27A33 27" TV
WHITE LINES
Replaced C407 100uf/35V Vertical section.
Mar 03, 2008 | Toshiba 27A33 27" TV
Black Vertical Lines 2" Thick On Both Sides.....What's Up????
There is a deflection problem that a shop can remedy. Expect to pay about 150 US for this repair...accordianman
Jan 09, 2008 | Toshiba 27A33 27" TV
Toshiba 27" standard def. TV
white narrow lines mean at the top of the screen called top retrace lines it is due to vertival section. any high value elec. cap might be defective.
Sep 13, 2007 | Toshiba 27A34 27" TV
Toshiba 27A33 27" TV Logo
85 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
