Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer not freezing
Our electricity was out for 4 days due to Hurricane Ike, we cleaned out our fridge and freezer and kept the doors open until power returned. We placed frozen food back in the freezer 12 hours after power returned. Since then, nothing will stay frozen. It's cold but more like a fridge than a freezer. We had the setting on coldest then we tried 3 to see if that would work. Still nothing will stay frozen except the ice packs we have in the door (ice cream is soup). However, the ice maker is working and the ice is staying solid. Please help!
    Scholar:
  • 142 Answers
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Posted on Oct 01, 2008
The fridge side is not getting cold even when temp is turned up. freezer side seems to be maintaining (things are still frozen)
It is possible that the air blowing of the fan is restricted due to freezing within the cooling coils, frost developing too much inside the coild, This can happen even if the door had been kept too long open or if the auto defrosting of the fridge is not working fine. So first of all deffrost off the fridge totally by shutting it off for about 8 hours. Clean up totally and restart after you think the cooling coils are clean and dry. Now check for the first 24 hours how the efficiency of the system works, is it better or worse or the same. If better it is sure you auto defrosting is not working and you will have to check up on the auto timer unit. If the same then check the speed of the fan and the blowing, set the temp in moderration to the freezer and the fridge to balance off, not too much for the freezer and try. I am sure the fault will be in this section. Hope you try this out. Good day
Jul 30, 2010 | GE CleanSteel GSL25JFTBS
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Frigidaire side by side - fridge side temp too low
It sounds as though your thermostat is not cycling your compressor off causing it to run until the point of freezing. If you sit and listen, you will hear it hum. If it never stops humming, 9 times out of 10, the power outage shorted your thermostat.
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
F & P Fridge/Freezer Model N395B freezing under vege bins
While staying with a friend that had this problem we assaulted the fridge. Pulling everything we could apart. After finding this link http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/FRIDGES/517579%20%20Series%20R%20N308R,308XR,325TR,369BR,375TR,395BR,400HR,4.pdf which had a parts list similar to the fridge we had. Pulled out the Defrost timer paragon located next to the compressor. After giving it a good shake it started making ticking sounds again. It appears that it is semi-faulty in our case and had stopped working.
Dec 04, 2008 | Fisher and Paykel Active Smart E522B...
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Problem with oven door latch
Hello noahsark,
Welcome to Fixya
You said, after Hurricane Ike, when the electricity came back on, you noticed the oven door latch was in lock position and the door would not close because it would hit the door latch. You guess the door latch locked on it's own with the surge of electricity but did not lock the door in place. And that you have never used the self cleaning oven, so the door latch has never been used. How can I get the latch to unlock itself?
Was the range get under water?
If so there may be some shorts in it or faulty electronic parts!
Try turning the range off and then turning the power off at the breaker for 5 minutes.
This is should reset the system in an electronic range.
If it works , great .
If not you may need service to diagnose your electronic problem.
Let me know that it works!!!!!
Send me the Brand and mode;l number.
Please remember to leave a rating when you finish.
Huuum
Oct 02, 2008 | Amana Kitchen Ranges
Samasung RS2577Sl
It might be that your fridge went into something called 'demo mode' that shuts the compressor down so as not to waste electricity on the showroom floor. The freezer and fridge sides both start to warm up, but the temperatures shown on the outside of the door never change, so you don't know you have a problem until you open the fridge or freezer and find you have a melted mess. My Samsung is 7 years old and we run into this problem frequently when our power is on and off, like just recently with hurricane Ike. Per the Samsung website, the cure for 'demo mode' is to unplug the fridge for 1 minute then plug it back in. They also suggested pressing Power Freeze and Freezer Temp together for 8 seconds until you hear a chime to cancel demo mode. Good luck. I really dislike this machine.
Jun 29, 2008 | Samsung RS2578BB Side by Side Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
326 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
