Question about Canon EF 50mm f/1.8 II Lens
Cleaning inside Canon 50mm /f1,8 II
Please, tell me if I can remove the dust myself, from the Canon lens 50mm 1,8 II. How I can do this without damage it?
Thank a lot.
ionut(dot)mihalake at gmail.com.
you can have a look here:
http://www.ejarm.com/photo/ef5018iidis/
and here:
http://nis-lab.is.s.u-tokyo.ac.jp/~ybando/rgb_filter/disassembly.pdf
HTH,
Jean-Marie.
Posted on Jan 19, 2009
Canon 50mm 1.8 error 01
Have a look here
http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/#err01
Seems to be a connection problem Clean to connectors on both the lens and camera with a pencil eraser.
Aug 30, 2013 | Canon EF 50mm f/1.8 II Lens
How to fix the communication error canon 1.8 50mm
Turn camera off, remove lens
Replace lens, turn camera on.
To help prevent it from happening again, you can try cleaning contacts on both camera and lens.
How do you remove the macro lens
The 50mm f1.8 lens is not a macro lens. If you attached a close up filter, it should just screw off. Try not to squeeze the ring too tight as that may make it harder to remove. Also "righty tighty - lefty loosey"
Nov 30, 2012 | Canon EF 50mm f/1.8 II Lens
I have dust particles inside my Tamron 17-55 LD XR DiII SP Nikon mount lens. Is there an easy way to remove them?
No. There is no easy way to remove them, to do so requires an expensive strip down and overhaul in a clean dust-free environment.
Unless you have the dust equivalent of boulders in there, then they are highly unlikely to show on your images and you can ignore them. Even if they do show occasionally you can usually easily correct the faults using commonly available processing software.
Jul 12, 2011 | Tamron 17-50mm f/2.8 XR Di-II LD [IF] SP...
I cannot get my new 50mm/1.8 lens off of my Rebel XT. PLEASE help!
Make sure you're holding down the lens release button, which is located on the front of the camera, while turning the lens. Sometimes a little bit of force is needed, I've found new lens' can stick a little bit. If it still won't come off, contact Canon.
May 10, 2011 | Canon EF 50mm f/1.8 II Lens
My lens fell down and I think is not broken but the front part is separated, can I repair it myself or should I sent it to customer service?
Get a quote first for the repair as this lens is the least expensive Canon lens and it could be that the combined cost of postage and repair will exceed to cost of a brand new replacement.
Feb 11, 2011 | Canon EF 50mm f/1.8 II Lens
Can i strip and clean the inside of my Cannon ef 50 mm 1:1.8 ii
You can. But do you have a lens collimator and other equipment needed to ensure proper alignment when you put it back together again? Without such gear, the resulting pictures will probably be worse than they are now.
May 15, 2010 | Canon EF 50mm f/1.8 II Lens
Can i strip and clean the inside of my Cannon EF 50 mm 1:1.8 II
I don't think so. the lens is held by 3 or 4 internal plastic hook clipping type . send it to canon cost about 30 bucks. one clip breaks, you can say goodbye to your lens.
Mar 30, 2010 | Canon EF 50mm f/1.8 II Lens
Err.1 of Canon lens
Maybe that's why it was for sale on Ebay.
Feb 03, 2010 | Canon EOS-1D Mark II Digital Camera
Canon EF 50mm f/1.8 II Lens Logo
2,551 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
