Dell 15 inch monitor, brightness/contrast window
The display for brightness/contrast remains on the screen, at times cycling through the EXIT, BRIGHTNESS, CONTRAST buttons. The display window for this is in the middle of the screen quite an aggravation.
  • 1 more comment
  • mehrajlone Jan 12, 2009
    your post as a comment to blu00z's Dell 15 inch monitor,
    brightness/contrast window problem, and notify you when a new solution
    is offered.
  • magistertexa Jan 23, 2009
    brightness window says "brightness 100" and stays in the middle of hte scren and alternately comes on and off. any help would be great. gratias.
  • Anonymous Mar 27, 2009
    Brightness/Contrast window arrives unbidden and cycles through the choices. Engaging a control, say "contrast", may cause picture to go to black because once started, the control doesn't respond to input.
    Champion:
  • 220 Answers
The front panel switches are known to become leaky.You need to replace these switches.
Samir.
Please rate the solution and provide feedback.
Posted on Sep 30, 2008
Press and hold the + button, You will get a message that the monitor is going into auto adjust. After that problem solved.
Posted on Jan 19, 2009
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
I don't know how to adjust the bright and dark for the screen.
To adjust the brightness and contrast, do the following:
1. Press the either the Minus button and highlight the option you wish to change.
2. Press the Menu button to select the highlighted option.
3. Press the - or + buttons to adjust the brightness/contrast settings.
4. Press the Menu button again to accept the changes.
Click the link below for the documentation on this monitor:
http://support.dell.com/support/edocs/monitors/e156fp/En/about.htm
May 23, 2011 | Dell E156FP 15 inch LCD Monitor
The brightness/contrast window pop up randomly and frequently. Brightness level keep on increasing automatically. Pls help.
A 15-inch CRT monitor? It's time to responsibly recycle it, and buy a 17-inch LCD monitor, because _nobody_ fixes CRT monitors any more.
Jul 03, 2010 | ViewSonic E50C 15" CRT Monitor
Desktop is continuing to display contrast as 100
Dear mahendra
Welcome to Fixya Customer support
This is common problem observed in many monitors compaq,HP,IBM this is happens mainly in rainy season due to moisture,by this moisture monitor botton circuit get rust inside and button pad remain pressed. so it shows a strip at the middle of monitor like contrast or brightness. So this is minor problem just replace the monitor display control button sensor or circuit.It deffinately solves your problem.
Good Luck
Fixya Customer Support
Chandrashekhar
Jul 22, 2009 | IBM E54 15" CRT Monitor
Brightness/contrast menu popup
Sound like either the button is stuck or the display is in error.
press and wiggle the buttons carefully, and disconnect the power to the display.
Feb 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Usercontrol automatically displayed when bootup
Please change the switch pannel  and check
Nov 19, 2007 | HP Compaq FS 7550 17" CRT Monitor
it is due to the 5V regulator ,replace that
Sep 15, 2006 | SAMTRON 55V 15" CRT Monitor
Dell E173FP 17-inch Flat Panel Color LCD Monitor
The dell monitors are bad with capacitors going out, check caps in power supply and video board. You can use a can of freeze, it would be easier that way. Just be careful not to touch anything, because these monitors can shock easy.
Sep 06, 2006 | Dell E173FP 17" Flat Panel LCD Monitor
Dell Ultrasharp 21' monitor
I had the same issue. I pressed and hold the + button and the monitor did an auto adjust and the pop up stopped.
Aug 23, 2006 | Dell UltraSharp 1702FP 17" Flat Panel LCD...
Computers & Internet Logo
885 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
