Question about HP DeskJet F380 All-In-One Printer
Scanner scanning a docu process step
Please your sent driver (CD), I  will instal to my computer.
Posted on Oct 02, 2008
Error code 0x80070005
Easy Way to Fix Error Code 0X80070005 - YouTube
? 4:04
https://www.youtube.com/watch?v=n9mHnVFrxUE
Aug 8, 2014 - Uploaded by Windows Error Support
Error 0X80070005 is a typical Windows Error Code. This error usually occurs during installation or Windows ..
Nov 17, 2015 | Microsoft Windows 7 Ultimate for PC
How can i stop the squelch ive tryed turning the sqcuelch doesnt help
Plug the AC adapter into the back of the scanner and into a wall electrical outlet. Screw the antenna into the receptacle on the back of the scanner (extend the antenna to full length for best reception).
  • 2 Set the squelch level to allow signals to be heard by turning the squelch knob counterclockwise. Rotate the volume knob clockwise until you hear static. Slowly turn the squelch knob clockwise until the static noise disappears.
  • 3 Start programming frequencies into the scanner by pressing the "Manual" button.
  • 4 Press the up arrow or down arrow key until the channel you wish to program is visible on the display.
  • 5 Use the numbers on the keypad to enter the frequency for the local transmitter you wish to receive.
  • 6 Press the "E" key to complete the process of entering the frequency.
  • 7 Repeat steps 3 through 6 for each additional frequency you wish to monitor.
  • 8 Press the "Scan" key to start the scanning process. The scanner stops on a channel when it detects a signal strong enough to hear over the squelch setting. Two seconds after the signal stops, the scanning process resumes.
  • Dec 06, 2011 | Uniden BC248CLT Base Scanner
    How do I scan a document to create a PDF
    Follow these steps :
    •1
    Position the first page of your document on the flatbed scanner and close the lid.
    •2
    In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
    •3
    In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
    •4
    Click "Scan."
    •5
    When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
    •6
    Repeat the above steps as necessary to scan a multi-page document.
    Oct 20, 2010 | HP J4680 Office Jet All-In-One Printer
    HOW DO I PROGRAM THE CHANNEL IN AND LEAVE IT ON SCAN AND IT PICK THEM UP
    To enter a known frequency into your scanner:
    - Power the scanner ON
    - Press the MAN key to stop scanning
    - Press MAN repeatedly to select the channel to program
    - Enter the desired frequency, including the decimal point
    - Press E to enter your data into the scanner's memory
    Repeat the process for other frequencies, and press the SCAN button when you're finished programming.
    More detailed programming steps are presented in the factory operating manual, which you can download/print, free of charge, here:
    http://www.uniden.com/pdf/BC60XLTom.pdf
    For a comprehensive database of active frequencies in your area, visit:
    www.RadioReference.com
    Bill B
    Aug 06, 2010 | Uniden BC60XLT Handheld Scanner
    Need to have a barcode that when scanned will simulate an enter
    There is not a barcode to simulate the enter key. You have to program the scanner to add the C/R (carriage return) to the end of the data that it sends. This is just a simple programming step. The users guide that came with the scanner will have a section in it with barcodes to scan to program the unit to perform differently. Each model scanner is a little different but the process is about the same. Enter programming mode, scan the C/R barcode, exit programming mode. Now when you scan the barcode the scanner will automatically add the "enter" for you.
    I hope this helps, if so please rate our solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Jun 15, 2010 | Symbol MC3090 Wireless Barcode Scanner
    How to scan a document in pdf format from hp psc 1315
    1. Position the first page of your document on the flatbed scanner and close the lid.
    2. Step 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
    3. Step 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
    4. Step 4 Click "Scan."
    5. Step 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
    6. Step 6 Repeat the above steps as necessary to scan a multi-page document.
    May 30, 2010 | HP PSC 1315 All-in-One Printer
    Use of Scanner
    On this model there is a SCAN in black and white or color buttons but you need to have something on the glass to scan. Once it scans it prints!!!
    Now lexmark software if installed comes with a program to scan with. you need to check under your prgrams folder under lexmark for the scanning software that was installed with the print driver.
    If you open the lid and you do not see the white light chances are your scanner has and needs a bulb inside and at the point to install one of these you might want to concider a new printer.
    Please be considerate and leave your feedback and comments and ratings before you leave, Thanks
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Apr 30, 2010 | Lexmark X2500 All-In-One Printer
    How do i scan using a HP desktop F380
    Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
    follow the steps below
    Step 1
    Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    FAXING MULTIPLE PAGES
    you can use the automatic docu feedr at the top of the machine to fax multiple pages just put all the pages you want to scan on that feeder then do the usual faxing steps
    Aug 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
    Scanner still scanning black, I don't think it was the bulb
    Well, I was HOPING that your problem was simply caused by a burned-out bulb, but since you can see a BRIGHT light when you use the scanner, the bulb is WORKING, and it is NOT the cause of your problem... Unfortunately, the only other known cause of "black scans" for your Microtek S400 scanner requires you to follow a rather complicated procedure to correct the problem, so I am in the process of typing detailed instructions for you to follow. I will post them here as an addditional comment as soon as I finish typing them, and hopefully, they will help to guide you through this process. I am posting this now simply so you will know that I am still working on helping you to resolve this; according to the Microtek Knowledge Base, there are several steps you MUST follow exactly in order to eliminate the cause of the black scans, so I ask for your continued patience while I finish my research into your problem. The instructions Microtek provides seem somewhat complicated, so hopefully, the instructions I'll post here will help you to understand the steps Microtek requires you to follow to correct this problem. Again, the solution to your problem requires that you follow several specific steps (Step 1 through Step 10), in order, depending on which version of the Scan Wizard software is installed on your system, so I will post more information here that should help to guide you through the entire process. If the first solution Microtek suggests does NOT correct your problem (following Steps 1 through 10), you will have to follow Step 11 in order to complete the process of removing the Scan Wizard software. Obviously, such a multi-step process will require a good deal of patience, and attention to details, which is why I'm trying to simplify the entire process for you... I'll post the steps here as soon as I finish typing them; please read through them, and if you have any questions for me, post them here, and I will try to answer them for you BEFORE you begin following the multi-step repair process... After seeing all of the steps involved in correcting this problem, I'm thinking of changing my screen name to ScannerHater...
    Apr 01, 2007 | Microtek ScanMaker s400
    HP DeskJet F380 All-In-One Printer Logo
    169 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
