Question about Metabo W14 125 Ergo Angle Grinder 5"
How to.... I just recived this angle grinder, it's not new and my father told me he hasn't used it for a long time. How can I change the disc? and how exactly to I use it?
  • 3,791 Answers
Most angle grinders arrive with a spanner; two if it is quite old. if you are not experienced with such tools and do not have the instruction book i strongly suggest you take a trip to your local hire shop and purchase a couple of discs and some goggles and explain your problem there. the staff there will be expert at giving tool virgins crash courses in the safe operation. dont forget a safety rcd for your electric plug.
Posted on Oct 05, 2008
How to Change a angle grinder disc
My angle grinder came with a special wrench to take off the disk. I have a small button to push that locks the shaft. I push it gently with it UNPLUGGED while turn the grinding wheel by hand till it locks. Then I use the wrench to undo the "nut" that holds the grinding wheel on.
Sep 27, 2014 | Saws
Misplaced my angle grinder's inner disc flange
If you use a nut, the arbor nut will not hold your grinding/cutting wheel properly and you'll use up threade the arbor nut needs to tighten. What you need is the clamping flange, Bosch part number 3603340501. If you have a tool repair center near you they may have one or can order you one. If not, you can get one on sites like www.ereplacementparts.com.
Dec 06, 2012 | Bosch 1800 4 1/2" Angle Grinder Cutoff
Hi...I have a Black and Decker 4247 angle grinder that I haven't changed the disc on in YEARS...I can't remember if the clamp nut is right hand threaded or left...please help! Thanks lots!
Which ever way your grinder spins when turned on is the same direction the lock nut has to be turned to remove it. This makes sure it's self tightening when in use. More often than not they're right-tight, left-loose.
Nov 26, 2011 | Saws
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
My Grinder is jammed wheel is moving very hard what should i do please suggest immediately
Just a shot in the dark, check to make sure "lock" is not partially engaged (Black button on top of grinder used when changing blades/discs)
Feb 28, 2011 | Bosch 5" Paddle Switch Small Angle Grinder
To sharpen tools
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
Jul 29, 2010 | Delta ShopMaster 8in Grinder with Light...
How do i change a disc on a angle grinder
There is a small button that locks out the shaft (where the disk attaches). You will need to push and hold down the button while you use the wrench provided to remove the retaining screw (there should be 4 holes in the retaining screw). It is a standard lefty loosy, righty tight. Good luck
May 21, 2010 | Garden
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
I have a brand new Grinder 230mm and now need to change the grinding disc however I cannot get the locking flange off - I have detroyed one spanner, and purchased a stronger one, but still no good. can...
Try turning it the opposite way. Instead of loosening it, you may be tightening it. Reverse threads on these machines are necessary to keep the flange from flying off by itself. Joe
Apr 12, 2010 | Black & Decker 9"/230MM 5,000 Rpm Large...
Metabo W14 125 Ergo Angle Grinder 5" Logo
220 people viewed this question
Top Metabo Saws Experts
Vernon Taylor
Spud Howell
JOHN LAPIER
Are you a Metabo Saw Expert? Answer questions, earn points and help others
