Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
No suction Brushes won't turn, belt attatched to motor but not spinning I have no suction in main part of the hoover.
  • ktokach Oct 08, 2008
    I have the same problem. No brush movement but the motor is running and the belt is intact. Any other suggestions?
  • Anonymous Mar 29, 2014
    Brushes don't spin
  • 372 Answers
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Posted on Oct 01, 2008
No suction or brushes turning after auto shutoff
Make sure that there are no clogs in any of the hoses. Also, check any belts. Make sure that they are in place and they are spinning.
Nov 12, 2013 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes won't turn
The brushes are powered by air suction from the motor. At the heart of this complicated system are roller bearings. When one fails the system fails. This is not one of the parts that Hoover thinks is needed on it's parts site so I've haven't found a way to repair this.
Jun 28, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Have a Hoover Model F5887-900 upright carpet cleaner. I am having issues with the attatchments. The brushes will not spin on the handheld attatchment and the solution trickles out. Any...
HI ,
I AM BILL AND I HAVE A SIMILAR PROBLEM. I HAVE FOUND THAT THERE IS A SHIFTER VALVE NEAR THE REAR OF THE MOTOR AREA.
IF YOU LAY THE HANDLE DOWN FLAT YOU CAN SEE WHERE THE VACUUM HOSE ATTACHES TO THE SUCTION MOTOR. CHECK THERE TO SEE IF IT HAS COME APART.
NEXT CHECK THE SHIFTER VALVE AND SPRING MOVE ROTATE 1/3 OF A TURN . WHEN YOU LOWER THE HANDLE THE SHIFTER HAS TO BE IN THE FLOOR MODE FOR THE SUCTION TO THE MAIN FLOOR SCRUBBER AND SPIN THE BRUSHES.
TO USE HAND TOOLS THE HANDLE HAS TO RAISE UP AND LOCK TO OPERATE ANY HAND TOOLS.
A PLASTIC LEVER BREAKS BY A SPRING CALLED THE SHIFTING LEVER. A SHIFTER VALVE LEVER IS THE RIGHT REAR, THE HANDLE DOWN. GOOD LUCK
MY PROBLEM ACTUALLY THE SHIFTER DOOR AND I HAVE A LOT OF SEARCHING TO DO TO FIND THAT.
OH! BY THE WAY THE LEVER PART # IS 90001320 $2.16 + SHIPPING AT SEARS PARTS DIRECT
Apr 29, 2009 | Vacuums
Hi, i have a hoover steam vac agilty. the brushes on the bottom front quit spinning. they are not locked up as i can freely turn them by fingers. is there a belt that i need to replace? if so, how do i get...
The brushes on all hoover steam vacs are air opperated it uses the suction of the vacuum motor to spin a turbine and in turn spin the brushes. Most likely that path of air is clogged with hair or carpet fuzz. On the top of the machine there is a little clear cover undr that cover there is a screen which keeps that hair for entering the turbine kinda like you clothes dryer lint trap. Take the cover off and clean that screen this should help. If you have any other questions or need parts for that machine or any other visit www.stevessewandvac.com
Aug 12, 2008 | Hoover Vacuums
I have the steam vac spinscrub upright. The brushes won't spin anymore.
Have you checked the lint screen? Your brushes are air driven if it's a Hoover Spin Scrub. There is a clear cover on the left side, when facinf from front. Remove this cover, about 3x5 inches and tapered, and clean the screen. Some units have a red or white screen that you can pull out from the bottom of the unit, left side just behind the brush block. Clean the screen then reinstall. Check that recovery tank is properly positioned- lack of seal means less suction which translates to brush block not turning.
Apr 16, 2008 | Vacuums
Hoover sttem cleaner
The brushes spin by virtue of an air driven turbine. This turbine uses a little of the motor suction to turn a large fan which turns the brushes. If you look behind the clear glass window on the front right hand side of the machine, you will see a screen which acts as a filter to keep debris out of the turbine. If this screen becomes clogged, it will affect the flow of air to the turbine and the brushes will slow down or stop all togeather.
Also, if the lid of the recovery tank is not on correctly, the suction will be compromised and the brushes will not turn and the machine will not pick up water off the carpet.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Hoover model 5906-900 spinscrub
Solution for Hoover SteamVac (F7452-900) brushes not spinning
Uses the turbine model and same solution would be similar. Root cause is simply the main gear attached to turbine becomes stuck. This problem should not happen as often as I see other people also having this problem. Must be a poor design on Hoover’s part. It takes about 30 minutes and a Phillips screw driver and wrench. Pretty easy, just have to remember what screws went where.
Remove brushes, and front suction cover
On the bottom of the machine:
Remove the 4 screws behind brushes which attach the top faceplate
Remove the 2 screws from base in the sunken holes
Remove the two long silver screws from base which connect all the way to turbine assembly
Stand machine upright
Remove the floor select switch handle
Remove 1 screw near the center beside the intake hole
Remove the 2 screws over the rear wheels
Remove faceplate cover, the front will need to be gently pried over the clear plastic part, be careful about the upright disengaging lever under faceplate, move it under the metal wire
Remove the 2 screws in the front of the turbine assembly
Remove the 2 hoses on either side
Disengage the bar on the floor selector switch
Pull out the turbine assembly
Remove the 4 screws and 3 clips to separate the assembly
Remove the filter (which is most likely clean since, cleaning this is the manufactures only solution)
Remove the large white gear and with a wrench remove ball bearing
Remove other large white gear
Note that the metal gear attached to turbine will not move (this was my problem), with a wrench gently grab metal gear and twist free. Spin turbine to make sure it moves freely.
Put everything back together again and you should be good to go.
Apr 12, 2006 | Hoover V1 SteamVac SpinScrub Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
105 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Roger Potts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
