Question about Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW
Ffu17fc4cwo commercial freezer , no suction from door and will not freeze
Freezer door will not suction closed, and it will not freeze
On Hoshizaki freezers, it has several items that can cause this. Check to see if the heater in the evap are heating up when in defrost. Older machine can force a defrost by just unplug and then plug back in to outlet to do this. There is a "Klixon" type thermostat that disconnects the heaters in case of an overheating condition. These go bad fairly often. Make sure the door closes and seals. Be sure not to do anything that hampers air flow over the evap.
Jun 25, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
What is hgv valve leaking by
The hot gas valve is activated during the machines harvest cycle letting hot gas defrost the evporator. If it is "leaking by " that means that it is not fully closing during the freeze cycle causing high suction pressures and inefficient operation of the machine. And maximum freeze cycles. If that is happening it will need to be replaced by a qualified technician.
May 09, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki dcm 500 freezing up suction line
This calls for a tech that is familiar with this stuff. I have one a work and it runs great but I can't fix me. There several things it could be. Is it waking water anywhere. And does it run constantly.
Jan 28, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Correct suction line pressure
If it is R22 then it will be about 11psig on the suction side. This should give you a -18 degrees across the coil.
Jun 30, 2010 | True 49 cu. ft. / 1388 liter Commercial...
What could cause an evaporator coil to freeze up on a true t-19f. Also what is the suction pressure on this model.
Could be low on freon,i belive this model uses 134A.
So the suction pressure should be 31 to 35 psig,for a temp of 36 to 40.f
Also check the defrost timer and the door seal. The eveap should have a drain line on it, make sure this is working and not plugged.
Apr 07, 2010 | True 19 cu. ft. / 538 liter Commercial...
Sub zero refrigerator model 532 problem the freeze is warm on the top but the ice & items below the ice are OK. i suspect that the light may be always on. also the freezer door does not make its...
I suspect a bad fan motor, door switch, or not defrosting.The suction when door closes is caused by the low temperature created when working properly.
Feb 14, 2010 | Freezers
Frigidaire 16.7 cu. ft. / 473 liter Commercial Freezer FFU17K1CW Logo
327 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
