Water leaking under dashboard - Heating & Cooling
    Scholar:
  • 121 Answers
There is a drain for your a/c thaht is probably clogged or if it is warm water you have the heater core or hose leaking.
Posted on Sep 28, 2008
2011 polo vivo leaking water under the dash,what could the problem be?
Are you leaking water when you wash your car or when it rains ? Or is it coolant leaking ?
If it's water, you may have clogged drain posts that run under and long the windshield, under the cowl area. Will need to remove this part and check the corners for dirt which tend to clog drain posts.
If it's coolant, you may have a bad heater core of damaged heater hoses. In this case, you will need to replace the component that is bad. May require to remove the dashboard which is best done by a skilled mechanic.
Jun 23, 2017 | Volkswagen Polo Cars & Trucks
Why would my jeep start leaking clear water under passenger dashboard
the EVap chamber drain hose is broken and now leaks
condensate water (pure) to the foot wells, and not to garage floor as it should, easy fix.
Sep 14, 2014 | 2002 Jeep Grand Cherokee
I am trying to find the source of a rain water leak in my escort 55 van. If the van is left standing whilst it is raining water drips from somewhere under the dashboard on to the floor. I have tried to...
You might want to check under cowl area which is under the wipers. I would suggest for someone to use a garden hose while you are under dash with bright light looking for leak.
Sep 16, 2013 | 2000 Ford Escort
Leak under dashboard
The only fluids under the dash are coolant that circulates through the heater core, or if you have a manual transmission a failed clutch master cylinder can leak brake fluid under the dash right where clutch pedal is located. If the heater core is leaking, it usually shows up on the passenger side. If it is just plain water, you need to check how rain water could be getting in past the firewall and under the dash.
Jan 06, 2013 | 2007 Nissan Frontier SE Crew Cab
2001 Jeep Grand Cherokee Larado has water pouring out from under the dashboard on the passenger side. Help!
The water gushing in on passenger side, is probably antifreeze, check that the heater core isn't leaking. If it is gushing try and capture some of this water and and see if it is antifreeze or just water. If antifreeze then it's the heatercore if water the. It's from the a/c
Sep 15, 2012 | 2001 Jeep Grand Cherokee
Water leaking under dashboard into passenger footwell
You may have a drain issue in the window channel, I f the widow is sealed correctly and the that is not the issue the then move to the drainage from the duct system the widow and air intake for the interior of the car has to be clear of foriegn matters. or the drain tube for that may be plugged
Jun 15, 2010 | 2002 Jaguar X-Type
Air condition water leakage under dashboard
Most likely the heater core is leaking and requires replacement.
As a temporary measure you may block off the coolant supply to the heater core - note you will also need to block off the coolant return line.
Nov 27, 2009 | 1984 Toyota Starlet
Water leak but not able to find out what part is called
Where is the leak?
Passenger side under dashboard area? (heater core)?
Near front of car? (Radiator leak)
Under fanbelts and pulleys? (water pump)
Under middle of engine (water hose)
Please .. more info.
Oct 05, 2009 | Mitsubishi Passenger Cars & Trucks
Heating & Cooling Logo
605 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
