Question about Hoover Washing Machines
Hoover 6 express 1200 - won't spin - Hoover Washing Machines
  • Hoover Master
  • 19,396 Answers
When it does not spin , it can be either a problem with the timer, a problem with draining and the drain pump, or a motor/motor control/belt problem.
Click this link for a detailed explanation: It doesn't spin
Posted on Sep 28, 2008
SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
Posted on Jul 23, 2009
SOURCE: Classixx 6 1200 Express washing machine manual
whay may nero 9 serial number it das not working? ma old S.N invalid
Posted on Nov 01, 2009
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
barkencoa
  • 3463 Answers
SOURCE: bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Posted on Jan 07, 2010
  • 500 Answers
SOURCE: My hoover 1200 express washing
Hi jacqui wa33,
Please follow my Tip below, for detailed directions on how to access, drain 7 clean your Drain Pump Filter (Please Note: Your filter is located Bottom Left corner):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Posted on Jul 13, 2011
Hoover 1200
Remove all excess water by draining to a bowl. Clear filter and drain pump blade and all will be fine.
Jul 15, 2012 | Hoover Washing Machines
My hoover 1200 express washing machine will not spin - how do I check the filter is not blocked?
Hi jacqui wa33,
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
Jul 13, 2011 | Washing Machines
Hi i was wondering if you help.my hoover hd vision
my hover washer dryer 1200 spin will not spin water comes into the drum and will not spin
May 12, 2010 | Hoover H160E Front Load Washer
Nov 01, 2009 | Bosch Washing Machines
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Hoover six express wont spin
all hoover machines spin in a clockwise direction the fact that you say the machine only washes in an anti-clockwise direction is a good indication that the reversing switches have failed (these provide the switching to drive the motor in either direction) if your machine uses a mechanical type programme timer this has failed if it it is a processor controlled machine it will be the motor drive card will need to be replaced either way not a diy task
Apr 21, 2008 | Washing Machines
Manual
Click on Hoover (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line.
Oct 05, 2007 | Hoover H120M Front Load Washer / Dryer
Washing mechine 1200 hoover
Hi, It sounds like it might need new brushes in the motor. Sometimes just before they wear down completely, they will wash but not spin, this is because the spin needs more power. Tom.
Mar 12, 2007 | Hoover H120M Front Load Washer / Dryer
Washing Machines Logo
1,141 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
