Question about HP Photosmart C6280 Printer
Scanning I was waondering if there was any way of scanning a drawing, and then putting it onto paint or photoshop but the scanner only gives two options, -(1)- Scan and Reprint -(2)- Scan onto memory card.
  • 234 Answers
If you are getting this message when you are trying to scan from the All-In-One on a windows operating system.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution /HP Director (if not got to Start> All Programs>
HP> HP Solution Center)/HP Director Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the
All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Good Luck
Posted on Sep 28, 2008
Doest scan
IF U have photoshop or paintshop pro or any graphics/paint program open it and choose aquire or import and then choose your printer and scan from there. If that works then the scanner is fine and you need to reinstall the scanning software from your disc or HP.com
Apr 18, 2014 | HP OfficeJet Office Equipment & Supplies
How to scan?? HP Officejet 6500
Use the Adobe Photoshop for scanning.
Start the Adobe Photoshop Then go to file menu then Import from Scanner.
That its. One more HP also gives a default application for scanning. Use your driver cd & install that application.
Oct 01, 2010 | Computers & Internet
Which scanner software i should install on my PC for IR3300
Install the driver for the scanner model and use any software that supports scanning via TWAIN or WIA like photoshop, imaging or paint shop pro.
Oct 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Fi-5750C Fujitsu scanner can't change grayscale default setting
Photoshop is not an "advanced" scanning program. To get some "production" and value out of this expensive scanner you need a professional scanning program which also may control the settings of the scanner. Use PixEdit which utilizes the built-in jpeg compression in the scanner. Did a test scanning 10 pages A4 duplex fullcolor. Adobe Acrobat Pro used 4 minutes. PixEdit used 20 seconds. Guess Photoshop (in your version) would also scan uncompressed and not use this good scanner optimal.
Jun 26, 2009 | Fujitsu fi-5750C Flatbed Scanner
Negatives scan as negatives and not as pictures with the plustek 7300
In the Twain driver for your intellscan, there should be a selection for the type of scan. It should be set to "black & White Negative" or "Color Negative". The program you use to edit the scanned file should be able to change it to a positive if the scanned result is still negative. Programs such as Photoshop, Paint shop Pro etc can use Twain to have the scanner scan directly into them. There the phot (negative) can be edited and saved.
May 30, 2009 | Plustek OpticFilm 7300 Film Scanner
HP 1410v all-in-one scanner won't work
Please follow the steps given below to scan from other applications.
Windows XP:
Scanning from Microsoft Paint:
1. Click Start, click All Programs, click Accessories,
and then click Paint.
2. Click File and then click From Scanner or Camera.
If this option is not available, Please let me know.
3. If more than one image source is connected, select the
HP all-in-one product and click Next. The scanning software
will appear. Preview the image by selecting Preview,
or click "Scan" to scan the image directly into Paint.
4. The image will open in paint for editing and/or saving.
Using Windows Image Acquisition (WIA)
Verify that the all-in-one product power is turned on and the printer cable is properly connected.
1. Click Start.
2. Click Control panel.
3. Click Scanner and Camera Wizard.
Follow the Scanner and Camera Wizard instructions to scan images to the computer.
If it is possible to scan from any of the above methods, try to scan from HP schortcut File and get back to me with the results.
Scan Shortcut:
1. Search for the file hpqscnvw.exe
2. File should be available in the following location
C:/Program files/HP/Digital Imaging/Bin folder
3. Create a shortcut on the desktop and double click the same
to activate the scanner and try scanning.
Windows Vista:
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs
3. Click Windows Photo Gallery
4. Click File and then click Import From Scanner or Camera
5. Click Import
6. Click Scan
Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate,
Windows Vista Business, and Windows Vista Enterprise.
1. Click the Start () icon.
2. Click All Programs.
3. Click Windows Fax and Scanning.
4. Click New Scan.
5. Click File and then click Scan.
Scanning with Paint
1. Click Windows.
3. Click Accessories.
4. Click Paint.
5. Click File and then click From Scanner or Camera.
6. Click Scan.
Scanning from Shortcut File
* Click on the Windows logo to access the start menu.
* Click on Computer.
* Double click on C:\drive icon.
* Double click on Program Files folder.
* Double click on Hewlett Packard or HP folder.
* Double click on Digital Imaging folder.
* Double click on the bin folder.
* Locate the hpqscnvw.exe file and double click on it.
Vishwanath V U
May 19, 2009 | HP PSC 1410v All-in-One Printer
Colorize drawings on Canon Lide 25 scanner?
Open Jpeg in a paint program or photoshop, add color and save as *.jpeg, so you keep the original
May 03, 2009 | Office Equipment & Supplies
Scanning drawing in 3 part and then putting them together as one.
my dear do i solve your problem?? just makes some technique of it,, tanks my dear ,, rate it plss
Mar 17, 2009 | Adobe Computers & Internet
HP Printer - Scanning Documents
i had the same problem with vista home premium. vista does not support one touch scanning (pressing the scan button on the printer). to use scanner with vista home os use the paint application and start scanning with the file section. step by step:
start (windows) icon lower left tool bar
programs
accessories
paint
file
from scanner or camera
the hp should start working - note: i sent a short cut to the desk top for the paint program for future use
Dec 06, 2008 | HP Photosmart C3150 Printer
UNABLE TO GET SCANER TO PRINT TO COMPUTER
Oks, first things first; 1. Have you checked the cable going from the scanner to the computer? 2. Have you ensured the drivers and software for the scanner, are correctly installed? 3. Have you checked to see if you can scan using your computer (e.g. via Irfanview, MS Paint, Photoshop, or whichever program you have that allows scanning?)
May 26, 2008 | HP Office Equipment & Supplies
HP Photosmart C6280 Printer Logo
102 people viewed this question
Ben Johnson
