Question about Grundig GF70-600 TV
Grundig television gu32dvd
Icant get the remote to work and also i have got the television stuck on keypad locked and witout the remote i cant get it off
2 Suggested Answers
SOURCE: What is code to get my sky remote to work my television
did you find the code ?
Posted on Feb 08, 2010
Is it possible time off the child lock witout remote.... pls hlp.... becouse remote is already damaged
Only if your TV has a button to "reset" everything back to factory defaults. Then you're still in trouble because you need the remote to program it all over again. Try buying a universal remote that's known to work with your TV model.
May 21, 2015 | Televison & Video
The sky remote will not operate the volume on my grundig gu22dvd have tried all the usual things codes etc but still doesnt work
Try an auto search with the remote, you might have already tried it :
1. press tv
2. press select and the red button simultaneously untill the LED light flashes twice
3. Then keep pressing the TV and Standby buttons one after the other (not at same time) until the tv swithches off, then press select to store the code, the LED should flash twice to confirm this.
Once you have the remote working the TV, you can get the remote blink back the TV code so you can write it down for future reference.
  • Press the TV button on the Sky remote
  • Hold down Select and the Red buttons together for approximately two seconds until the LED blinks twice
  • Key in 9, 9, 0
  • Key in 1 on the numeric keypad and count the number of times the Red LED blinks. This is the 1st digit.
  • Repeat for 2 and 3
  • Note: no Blink = 0 (zero)
Sep 09, 2014 | Grundig GU22DVDPX 22 in. LCD TV
Have grundig gu22dvd tv and can not get volume on the sky remote have tried the normal things and have code but still doesn't work
1. press tv
  • Key in 9, 9, 0
Key lock on soniq plasma tv witout remote control
Unfortunately the key lock cannot be deactivated without a remote, for it will defeat the purpose of key-locking. You can order a replacement remote, you need to have the exact information of your TV's model/version ( the barcode on the back of the TV starts in REVxxxx).
Sep 28, 2012 | Televison & Video
I have a Grundig TV GU32DVD keeps switching off but after several times of remote on & off it eventually stays on
Hello
Check the remote control for its infrared signal radiation. The remote may have the fault. Clean it, if you can. The proceedings to check and clean the remote can be get from the following link.
Feb 27, 2012 | Televison & Video
Grundig GU22DVD - Manual Instruction & cancel PIN Code
Please i have this Grundig lcd tv,model number GU22DVD,how to enter service mode to change sound standard PAL I toPAL BG,help me.
May 14, 2009 | Grundig GU19WDT 19 in. LCD TV
Grundig tv
some times on the universal remote ther are more then 1 code that will work with your tv. some codes will only do some things try all the codes on the remote for that brand. you should find one that works for you with 3 remotes you have a better chance of getting the right one hope this helps you
Jun 13, 2008 | Grundig GF70-600 TV
Tv on standby
Hi Kjunse,
The Television may be faulty, but without reading the manual I can't say for sure. If you want to risk spend some money to find out, here is a link to a website selling the remote control you require for the GF70-600 TV. I've not had any dealings with the company but you could always contact them to check your buying an original (OEM*) Grundig remote before you buy one.
*OEM means, Original Equipment Manufacturer.
Hope this is helpful.
Regards,
Spare head 2.
Jan 04, 2008 | Grundig GF70-600 TV
How to unlock a grundig t63-640?
Swich off tv from main swicher. Press i on remote control and hold it. Swicn on the tv from main swicher. On the screen should appear a service menu. Under decoder level with volume button from remote change from off to on. The same is with hotel mode for volume control. Exit the service menu by presing i on remote control and have a nice day!
Dec 27, 2007 | Grundig GF70-600 TV
Televison & Video Logo
82 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
