Question about Precor 933 Premium Series Treadmill
Displays "stop key" and won't do anything. This has done this before and had to replace stop key button. Is this a problem with this model?
    Top Expert:
  • Precor Master
  • 12,223 Answers
1) Remember that is important key, the cycle of work is a lot, add the dust, environment, etc.
2) Now i will recomend to you, clean with cleaner contact( radio shack or computer store) each week, try to take out the covert and do it, very carefully, disconect the power cord for to avoid ESD. In other word maintenance, with more intensity.
This will be avoid to exchange often.
sincerely.
E.CUADRA
Posted on Nov 18, 2011
SOURCE:
Genesis GO-127 vending machine help. Vending machine accepts bills/coin displays amount taken but buttons pad won’t allow you to press anything. I bought new key pad but still unreaponsive. HELP!
My friend, this type of machines have a com and or control center where the control pad is assembled to.Maybe the IC unit is not working at all or a connector is faulty. Check for all the connections or try to replace the IC main unit.
Nov 22, 2017 | Retail Supplies
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Nordic Track C2200 Error Code 440-17E what might be wrong?
reset the machine, follow this step and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Oct 21, 2013 | Exercise & Fitness
Horizon t207
follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 08, 2013 | Horizon Exercise & Fitness
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
The tray on DVD won't open when pressing OPEN button DVD/CD is inside
Often the tray is powered by a rubber belt. If the latter breaks or slips the try will not open/close. The motor will work and tell the electronics that all is well because it has done its job but it really hasn't since the tray is inert!
Sep 10, 2017 | RCA DRC247N DVD Player
Sole treadmill won't go in to sleep mode
You need to go into the maintenance menu.
Take out the red safety stop key, hold down the "start", "stop" and "Enter" buttons, keep holding them down while putting the red key back in (a bit tricky), keep holding the keys down until you see "Maintenance menu" scrolling (this will happen as long as you didn't let go of the three keys).
Initially when you put the red key in it'll might show software version etc, after a few seconds it'll change to maintenance menu. Use the speed UP and Down buttons on the console or arm to scroll through menu until you reach "FUNCTIONS" press enter.
In the functions sub-menu, depending on what year model/software version it has, it should have a selection called "Sleep Timer" if so set it using up down keys to "ON". If your model doesn't have "sleep timer" listed (i.e. a newer model) it's now just called "DISPLAY" and in that case set it to "OFF". That should fix it.
Press Stop, to go back. If you want you can disable the key tone/training beeping as well in the "functions" sub-menu of the "maintenance menu".
To exit press stop repeatedly until you're back to the normal display.
Dec 30, 2012 | Sole Fitness F63 Treadmill
How do you shut this thing off . the lights on the display stay on. reebok 8700es
Hols the stop button and the speed decrease button down while inserting or attatching the key (magnet). There should be a "d" on the screen, press the incline down button and it should go away. As soon as it disappears, your done. Just pull the key off and your display will shut off.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 06, 2010 | Reebok 8700 ES Treadmill - Silver Service...
Why won't my vision fitness simple T9500 run? I tried holding down the stop button for 3 seconds. It did clear the screen. Then when I hit start it puts 6000 in the screen and will not run. It beeps as if...
With the safety key in place, press and hold “ELEVATION UP” and “SPEED DOWN” for 5 seconds. The software version will appear in display window shortly before model number appears. Press “ENTER” to accept correct model number IF YOU CANNOT GET INTO CALIBRATION EITHER UPPER CONSOLE ELECTRONICS OR OVERLAY CONSOLE ASSEMBLY HAS FAILED.
• Press “STOP” to enter “ENG1”. Press “ENTER”. PLEASE NOTE: HR Window = “0” for miles, “1” for kilometers, treadmill will calibrate in kilometers if set for kilometers. STEP 2 MINIMUM SPEED • Press “ELEVATION DOWN” button, “P0” will appear in display. • Press “START” button, the running belt will begin to move at minimum speed. • The display window should read approximately “.49 - .51”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “.49 - .51”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P0”. STEP 3 1/4 SPEED • Press “ELEVATION UP” button, “SP1” will appear in display. • Press “START” button, the belt will move 1/4 speed. • The display should read approximately “2.71 - 2.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “2.71 - 2.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP1”. STEP 4 1/2 SPEED • Press “ELEVATION UP” button, “P1” will appear in display. • Press “START” button, the belt will move at 1/2 speed. • The display should read approximately “6.72 - 6.73”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “6.72 - 6.73”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P1”. STEP 5 3/4 SPEED • Press “ELEVATION UP” button, “SP2” will appear in display. • Press “START” button, the belt will move at 3/4 speed. • The display should read approximately “9.41 - 9.43”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “9.41 - 9.43”. Press and hold “ENTER” to save changes. Press “STOP” to return to “SP2”.
STEP 6 MAXIMUM SPEED • Press “ELEVATION UP” button, “P2” will appear in display. • Press “START” button, the belt will move at maximum speed. • The display should read approximately “12.10 - 12.12”. • To adjust, press “SPEED UP” or “SPEED DOWN” buttons, the range should be “12.10 - 12.12”. Press and hold “ENTER” to save changes. Press “STOP” to return to “P2”. STEP 7 MINIMUM ELEVATION • Press “ELEVATION UP” button twice, “P4” will appear in display. • The display should ready approximately “190 - 205”. • To adjust, press “ENTER” for value which should read “190 - 205”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P4”. STEP 8 MAXIMUM ELEVATION • Press “ELEVATION UP” button, “P5” will appear in display. • The display should read approximately “750 - 765”. • To adjust, press “ENTER” for value which should read “750 - 765”. Use “SPEED UP” or “SPEED DOWN” buttons. Press and hold “ENTER” to save changes. Press “STOP” to return to “P5”. REMOVE SAFETY KEY TO EXIT ENGINEERING MODE REPLACE SAFETY KEY AND PRESS START TO TEST TREADMILL
Jun 14, 2010 | Dmm Vision Fitness T9500 Treadmill
Precor 933 Premium Series Treadmill Logo
189 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
