Question about Kenmore 44102 Front Load Washer
Kenmore Elite Front loading washer
Out 4 year old washer stops several times during a cycle with an error message "FH'. We've had a plumber check the water supply and that is fine. This happens no mater how much is in the washer. Any ideas??
  • dona2190 Nov 29, 2008
    My kenmore elite front load washer will go partway through a cycle, and then start flashing FH> macine will wash, drain, spin, but will not rinse clothes. This washer is only 3 years old, I have the dryer that matches, and it is having problems too. NO MORE SEARS PRODUCTS FOR ME!!!!!
    Problem Solver:
  • 5 Answers
It is the mother board get new one.
Posted on Sep 28, 2008
I have a Kenmore elite HE3T front load. It gets down to 6 min then stops and flashes between 06 and F, what can i do?
Kenmore 110 4996 Use And Care Manual Troubleshooting
  1. "F" Variables [other than FH and F02] (=Electrical Problem)
  2. Select STOP twice to cancel the cycle.
  3. Select DRAIN & SPIN if there is excessive water in the washer.
  4. Unplug the machine for thirty seconds to reset the Central Control Unit
  5. Re-select cycle and press START.
Feb 27, 2015 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Dec 22, 2012 | Kenmore HE3 Steam 7.2 cu. ft. Super...
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Nov 28, 2010 | Kenmore Washing Machines
Getting an FH error code during the cycle count down
The FH code indicates it is not detecting water fill at the flow meter. Since you say that the washer is filling okay, I would check the wiring between the flowmeter and the control board. A common cause of this problem on this machine is the wiring harness jiggling loose. Unplug and reseat the wiring harness and see if it clears up the problem. Also look for and clean out any corrosion build-up where the harness plugs in. Hope this helped and best wishes.
Aug 05, 2009 | Kenmore Elite 45986 Front Load Washer
F H code during cycle, will not complete cycle
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This is one of the more involved error codes to try to resolve, because it can have various causes. The first thing to try before troubleshooting is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that it takes to correct momentary glitches. If the error code reappears, I suggest you begin with the easy items that you can eliminate first. Double check your fill hoses and water source, followed by verifying your drainage to ensure you don't have a siphoning problem and checking your drain pump for clogs.
If you still have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3 flashing FH
The following link explains the "FH" error:
This can be a rather tough one to figure out, even with the error code explanation. I would recommend unplugging the washer for AT LEAST 30 minutes first. This will reset the Central Control Unit (CCU). In many cases this is all that is required to correct momentary glitches with the unit. If the error code reappears, check your washer installation to rule out the easiest possiblities, first. This means checking to ensure you don't have a siphoning condition, checking your drain lines and checking to ensure your fill hoses aren't kinked or clogged. Read through the link thoroughly and let me know if you have questions. I hope this helps you.
Jan 09, 2009 | Kenmore 46462 Front Load Washer
Kenmore elite top load washer
error code with this? f11 or f22 are control board related commucation errors.
Jun 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Mar 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44102 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Robert Rankin
