Door wont open - Washing Machines
  • 958 Answers
The door switch could have stuck closed. there is a way to open it up manually.
if you can just access the water pump filter cover, and at the back part of the door switch you will find a plastic ring attached to the door switch, pull it down to open the door.
drain first the water if there is water left in the unit by slowly opening the water drain filter cover and drain the water slowly.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
1994 lincoln town car passenger door wont open
HELP! How to open "stuck" door - New Edge Cougar Owners
www.newcougar.org > Forum > General > Problems
Mar 9, 2009 - 11 posts - ‎8 authors
Hello all, The driver's side door on our 2000 is "stuck" closed and wont open by key, keyless, ... 1994 Lincoln Towncar w/ 112576 CRUSHED
door help lincoln town car 1994 - YouTube
? 3:04
https://www.youtube.com/watch?v=5yzIfHFU9CI
Sep 18, 2011 - Uploaded by Frank connors
door help lincoln town car 1994 ... owners of Town Cars with hinges that are failing on the driver's door -- and sometimes on other doors also.
Lincoln rear passenger door wont open Questions ... - Fixya
www.fixya.com > Forum > Tags > rear passenger door wont open
Jan 05, 2016 | 1994 Lincoln Town Car
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
Passenger sliding door and rear cargo door wont unlock but other doors will why?
window is an issue by itself.its most likely a bad window regulator or a motor or a switch.the sliding door and back door might be an issue with power door lock actuator.or broken handle
Jun 20, 2013 | 02-03 Caravan 2 Tire Pressure Sensor...
2006 jetta door wont open from inside or outside
link connector broken inside door, Remove door card and repair
Nov 16, 2012 | 2006 Volkswagen Jetta
Drivers door wont open
Chrysler2008 sebring drivers door wont open all other doors and central locking working including drivers door but will not open any suggestions..
Jun 01, 2012 | 2007 Chrysler Sebring Sedan
Passenger door wont open
It wont open from the inside? The outside? or both?. Inside the door panel there is a linkage responsible for opening the doors. If they are not connected then it wont open.
Nov 23, 2009 | 2002 Land Rover Freelander
Driver side door wont open.
You can't.. you've got to open the door. sorry.
Jun 26, 2009 | 2001 Hyundai Tiburon
1990 honda drivers door wont open
door latch is jam the last time i change one took 1and a haft just to break that stupid door lacht you have to be carefull you have to pry to door panelon top its not easy good luck pierre
Jul 29, 2008 | 1990 Honda Accord
Washing machine door wont open
well, Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Jul 19, 2008 | Washing Machines
Washing Machines Logo
335 people viewed this question
Top Washing Machines Experts
