Question about ASUS Eee 4G Notebook
Display panel stays dark.
I inadvertantly hit the F2 key and the resolution tab just above it and the panel went dark and I can't get it back on.
    Genius:
  • ASUS Master
  • 1,250 Answers
This might be due to the fault of the cable attaching to display panel, check it by some hardware engineer near you
Posted on Oct 03, 2008
Half Screen
It is either the lcd panel OR the video card / motherboard or it could just be a completly bad driver.
If you turn it on and hit f2 or f8 does it appear in this screens?
If not, it is a bad driver.
If a bad driver, turn on hit f8, choose low video resolution mode, surf to your manufacturers website, download, install and reboot.
Try display to an external monitor, if the line appears on the external monitor, the issue is a bad video card.
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
If the issue does NOT appear on the external monitor, the issue is the lcd panel.
May 02, 2013 | Acer Iconia Tab A50010S32u Notebook
Tried to enlarge the screen and screen went black and now showing this! I turned it off and hit F8! It came on I pressed safe mode! I tried to get on Internet and it locked up again ! Back to this scr
When a monitor displays "Input not supported", the display resolution is set too high. To resolve this, change the resolution to a supported resolution of the monitor.
In Windows XP
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
  2. On the Settings tab, under Screen resolution, drag the slider to the desired resolution and click Apply.
  3. When prompted to apply the settings, click OK. The screen will turn black for a moment.
  4. Once the screen resolution changes, confirm the change by selecting Yes. A timer will count down for 15 seconds to ensure the change is desired.
    Click Yes to confirm the change; click No or do nothing to revert to the previous setting.
In Windows Vista
  1. Press the Start button , select Control Panel, select Appearance and Personalization, select Personalization, and then Display Settings.
  2. Under Resolution, move the slider to the desired resolution and click Apply.
Oct 20, 2012 | Computers & Internet
Laptop with white stripe down centre of screen
Hope this helps
Sep 16, 2012 | Packard Bell Computers & Internet
Hi, Fn+f1 and Fn+f2 keys are not working to change screen resolution in my new hp probook 4320s laptop after i replaced its LCD. Please help me as early as possible. Thanks a lot in advance.
The screen rsolution is changed in the Display settings.
Open Control panel - click on Display - Settings Tab then move the slider on Screen Resolution to adjust the screen resolution. - then Apply
Mar 19, 2011 | HEWLETT-PACKARD ProBook 4320s C Notebook
I must have hit a button inadvertently and my screen is too big ...I want to zoom it back down down to 100%. How do I do that?
Right click on a blank area of the screen then select the graphics option in the box that comes up
You neglected to mention the operating system so the actual advice from there would vary but at least you are in the area you need to be.
take it down to about 1024x768 to start with and gradually increase until you get the result you desire.
Jan 27, 2011 | Gateway LT2021u Netbook
How can I adjust the screen wobble on a alienware aurora m9700 laptop.
Choose Screen ResolutionFor higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpgControl Panel: Display: Settings tab: Screen resolution
May 29, 2010 | Alienware PC Systems Alienware Aurora High...
Resolution problem
install your graphics card driver first
Aug 30, 2009 | SAMTRON 55V 15" CRT Monitor
Everything is larger !
In the personalize menu click display settings and go to advanced tab. In advanced tab drag the resolution slider to the right and keep it as 1024*768 and click apply and ok.
Revert back for any clarifications.
Apr 06, 2009 | Dell Studio Hybrid Desktop Computer
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
2 In Control Panel:
  • Select Display.
In Control Panel:
  • Press ENTER.
  • Press ENTER.
  • Select OK.
  • Press ENTER.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Connecting to a lcd projector
You may want to try adjusting the screen resolution and then hitting the function + F8 (or whichever key has the little monitor logo on it). Some resolutions cannot display on certain projectors.
You can find this setting in the Control Panel, Display, then Settings tab.
Dec 10, 2007 | Toshiba Satellite A10 Notebook
ASUS Eee 4G Notebook Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
