Question about Levelone CP TECHNOLOGIES LEVELONE WIRELESS-G WNC-0304USB 802.11G USB ADAPTER W/WI-FI DETECTOR (Retail) 802.11g/b
Can't connect to my router but can see it has a good signalstrength. Can't get the (new ?) IP-address from the router. Downloaded software from CD O.K. Has put Windows Zero Configuration to automatic and started it in the Control Panel Administration.
    Guru:
  • 1,894 Answers
Buying a Nintendo Wifi USB Connector for $20 at best buy
for some reason firewall may be blocking your signals
Posted on Sep 28, 2008
  • 13,433 Answers
Have you set the security settings and everything else correctly?
if your not sure, you can reset the router to default settings by holding down the reset button for 30seconds. after that you should be able to connect easyly, you will just need to configure the security settings on the router pages again.
Hi there,\r\nWe have a Linksys WPS54G print server and I'm trying to re-connect it to the new Veridon Fios router. The print server has a default ip address of IP Address:169.254.53.156 but the new router...
The problem is that your printer can't obtain an IP address from your router so it is kicking back the IP address 169.x.x.x which indicates it can't reach the router. You need to go into the IP address configuration on your printer and set a static IP address on the same subnet as the router. For example your router's IP is 192.168.1.1 so set your printer's IP address to 192.168.1.5 and set the default gateway on the printer to the router's IP address (192.168.1.1) next you need to enter in the DNS Server address which is also the router's IP address (192.168.1.1). Once you do that you will be on the same network as your router. From there you can add the printer on your computer through devices and printers if its a Windows pc. Cheers! J the Guru
Oct 16, 2017 | Linksys Computers & Internet
I have wildblue and my connection will not consistently connect . It freezes up the computer running xp wireless router is WNR854T
With wireless connections, there are at times brief disconnects. If you set your computer's ip address to a fixed value, this may help the problem. With a DHCP connection (not fixed) you could be getting a different address after one of the temporary disconnects causing the hang. Go to control panel, network connections, properties, then scroll down the window to the tcp/ip line , highlight it, then click the properties button. In the properties, click the use ip address button, enter a fixed ip address. If you are using a standard home address system, use 192.168.1.10 (if you have more than one computer, make sure each address is unique). subnet mask is 255.255.255.0, gateway is your router ip address, typically 192.168.1.1. Check your router information to be sure. You can use your router ip for the DNS server ip. If that does not work, check the DNS address provided in your router settings. Save all the settings.
See how that works, if it works, please leave feedback.
Good Luck
Feb 13, 2010 | Computers & Internet
I can't configure my Linksys router. I type in the 192.168.1.1 on my browser, and I never get the login page and such. I need to configure it nfor my new computer. I've tried it on both my computers and...
You need to first manually configure your computer with an ip address in the same subnet as the router. Go to the control panel and find the adapter that is physically(or wireless, doesn't matter) connected to the router.
Next, select Properties for this adapter and pick the Networking Tab. In here, select Internet Protocol V4.
Check the radio button that says "Use the following IP address" and enter the follwing info:
IP address - 192.168.1.2
Subnet mask - 255.255.255.0
Gateway - 192.168.1.1
Now you should be able to configure the router. Be sure to change the above settings back to "Obtain an IP address Automatically" when you are done configuring the router if you set up DHCP on the router. If you don't you'll end up with duplicate IP addresses and things will break.
Good luck, and let us know if you need more help on this.
Aug 28, 2009 | Linksys Wireless-G WRT54G Router
I have an EBR2310 D-Link router (not wireless). 2 mac computers are connected. The older computer is connected to the internet but I am having trouble connecting my newer mac to the internet. Earthlink...
I would check to see if your getting an IP address from the router. If you are, try to see if you are able to access the router.
http://www.ehow.com/how_4550065_check-ip-address-mac-os.html?ref=fuel&utm_source=yahoo&utm_medium=ssp&utm_campaign=yssp_art
Type the router's IP address into your safari window: Usually 192.168.1.1
If you have a good IP but still can't access the website, there could be an issue with your new mac computer. Here is the toll free support line for mac: U.S. iPod and Mac technical support: 1-800-APL-CARE (1-800-275-2273)
Jul 12, 2009 | Computers & Internet
Secondary computer will not connect wirelessly; IP address problems.
If the router is not assigning an IP then you are probably not actually connecting to the network. Try disabling your wireless security on the router and see if they connect. If they do then you know the problem lies in that direction.
May 31, 2009 | Linksys WRT350N Wireless Router
Dynex dx-ehb4 will not change ip addresses
I am not familiar with that router so I will provide general knowledge and you can apply it to fix your problem.
It sounds like your cable modem is willing to supply a single IP address. This can and should be connected to the WAN port of your router. The problem is that the router is not assigning IP addresses to the equipment that is connected to its LAN ports. Instead, it allows that single cable modem IP to be assigned to connection #1 and everybody else gets nothing. Get the computer working through it, connect to the router as per the owners manual and turn on NAT or DHCP, whichever it offers. Reboot the computer and connect xbox and you should be good. This was probably not an issue with DSL because your DSL modem would supply up to about 10 IP addresses and they also passed through the router.
Mar 03, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
Wireless router won't connect to my laptop
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
Hope this will help
Nov 24, 2008 | Arris WR850G Router (DHWR850G)
Need to change ip address for my camera
How is your webcam connected to your network? Is it connected to your PC or your router?
If it is connected to your router, go into the router settings and see if the router reassigned a new ip address to the camera. If you set the router up for DHCP, it will automatically assign IP addresses to all devices that are connected to it, as long as the individual devices are also set to dynamic IP addressing. Your router is set up for the 1.0 network, so your pc is most likely 1.2, while your router port connecting to your home network is 1.1.
Another thing you can do is make sure your webcam is turned on and go into 'My Network Places', then click on workgroup computers. See if the webcam is listed there.
Apr 11, 2008 | Toshiba IK-WB01A Network Camera
Laptops do not recieve IP address from the router
Carlos
I think the problem lies within the dhcp of your router. Make sure dhcp is on and change the lease time to 1440 minutes or higher that way once you have the ip address it will stay with your laptop longer. alternatively allocate the ip address on your laptop manually.
good luck
smeags
Jan 03, 2008 | Trendware TEW-452BRP Wireless Router...
Levelone CP TECHNOLOGIES LEVELONE WIRELESS-G WNC-0304USB 802.11G USB ADAPTER W/WI-FI DETECTOR (Retail) 802.11g/b Logo
83 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
