Question about GPS
Connect PDA TO GPS
I am trying to connect my pda to new Gps device, I have paired them, how do i know what serial port it should be connected to?
  • Lilacbiddy Sep 28, 2008
    It worked...
    I feel very stupid now. as I was near the window and thought it would pick up!!
    Guru:
  • 1,894 Answers
You can start using one you have paired them.
connect your pda to your systems port.
Posted on Sep 28, 2008
  • dewan nafees ahmed Sep 28, 2008
    if you are trying tomtom then here is the exact help you need.
    http://www.freeitsupport.net/viewpage.ph...
    thank you
    good luck
    First go to show GPS status and press configure, ( GPS staus is in the change preferences menu)
    Press configure.
    The correct setting for TOMTOM software are
    sellect other cable GPS, leave baud rate at 4800 and then GPS on Navigator is the com port
    GPS only works outdoors and you need to go outside to get a signal, it will take about 4 mins max to get a signal.
My garmin GPS 12 needs a serial port connection. New HP laptop with Windows 7 OS only has USB connections. Salesman sold me a Belkin F5U109 adapter but windows wont recognise it.
You should install the drivers for the adapter running as administrator. If the adapter is not supported by windows 7 you should give it back to salesman and get a new one compatible with windows 7
Mar 13, 2011 | Belkin USB PDA Adapter [ F5U109 ] (109198)...
Is there anyway to get a bluetooth phone and bt gps to pair if they won't communicate with each other
I have on occasion been able to get my NVM 4070 to connect with my phone. I have tested several different phones with this GPS. I noticed that if you are using a smartphone or pda it has trouble connecting. However, if you try and connect a basic phone, like a Motorola Razr, it has no problem.Overall it is a frustrating process that involves quite a bit of superstitious behavior, on my part, to get the devices to connect. Try restarting both of them.
Once you actually get them to connect, good luck. Like I said, I am able to connect mine, but usually once I leave my car, I have to start the pairing process all over again.
Jul 18, 2009 | Sanyo EasyStreet NVM4070 GPS Receiver
Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Dec 10, 2008 | Computers & Internet
I am unable to connect my mobile
Reset your device
Reset your TomTom using a straightened paper clip.
If you use a PDA, check the manual that came with your PDA to see how to reset it.
Install the latest application
We recommend always having the latest version of our application installed on your device.
See also: How to check for and install an updated version of the TomTom application?
Jan 07, 2008 | Tomtom GO 700 GPS Receiver
Communication Timeout
Under connection settings switch off the "beam" - apparently there is a conflict between the IR beam port and one of the ports used by the GPS system. Has worked for me.
Oct 26, 2007 | Fujitsu Siemens Pocket Loox N520 Pocket PC
E570 with GPS and Navi
Personally I have not GPS on my PDA but there is no reason that it should not work properly. The only thing is that you should pay attention on several things. Check by software producer if the software is compatible to your PDA. Please also be careful which ports use GPS hardware because your PDA has no USB port just serial port. With another words check all this important things before you buy anything.
Sep 11, 2005 | Toshiba e570
E310 and GPS
Before you buy the GPS for your PDA please be careful if the GPS manufacturer guaranteed the functionality with your PDA. I have e800 and I plan to buy the GPS for my unit. Unfortunately at the moment I have no information which one you should you use. You should have a look at the following document, to see how to setup a BT connection to your BT -GPS device. http://aps.toshiba-tro.de/bluetooth/redirect.php?page=pages/howto.html http://aps.toshiba-tro.de/bluetooth/pages/howto/How_to_use_a_Bluetooth_GPS_Receiver_v002.zip
Sep 11, 2005 | Toshiba e310 Pocket PC
Problems with e800BT and com ports
I use an e830 with a Holux GR230 without having any problems. The e830 uses already the latest stack from Toshiba so no need to upgrade. For the e800, hm depends on what kind of BT SD card you use, meanwhile Toshiba sells the BT SD3 card. Anyway, I would recommend to use the latest BT stack from Toshiba for your Toshiba BT SD card.
Sep 08, 2005 | Toshiba e800 Pocket PC
E750 use with Garmin 76 GPS
If no one has any solution for your issue in my opinion you should check the manufacturer’s site. Maybe there you can find out if this unit is compatible with your PDA. Usually you can find it under support or FAQs.
Sep 08, 2005 | Toshiba e750 Pocket PC
GPS Logo
207 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
