Question about Refrigerators
My refridgerator is not as cool as it use to be and the freezer is not freezing all that hard it completly melted 2 days ago and now its making ice cubes hard. I checked the power to the compressor and its working i also checked the power to fan I have power to fan. The fan doesnt seem to be kicking on Does all the wires have to be connected in order to have compressor and ice maker, and fan. Thank you Mary Im not sure how often the fan kicks on or does it stay on The only thing that I can seem to get is there isnt any
  • 958 Answers
Hi mary,
you said there is power to the fan? which fan?..the one near the compressor or the fan inside the evaporator coil?
if it is the fan near the compressor, it should be running if there is power. if the fan is sticky, lubricate the bushings of the fan with lubricating oils.
if the compressor is running and the fan is not running, the compressor will overheat and cutoff the thermal overload of the compressor. that would explain the problem of not getting coool as before.
tnx 4 using fixya,
drcool
Posted on Sep 28, 2008
    President:
  • 2,712 Answers
Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poorcooling is often the result of a heavy frost build-up on the evaporatorcoils. You can't see these coils without removing a panel on the insideof your freezer. A sure sign that there is a build-up is the presenceof any frost or ice build-up on the inside walls, floor, or ceiling ofthe freezer. Such a frost build-up usually indicates a problem in theself-defrosting system or damaged door gaskets.
The refrigeratoris supposed to self-defrost approximately four times in every 24 hourperiod. If one of the components in the self-defrosting system fails,the refrigerator continues to try to cool. Eventually, though, so muchfrost builds up on the evaporator coils that the circulating fan can'tdraw air over the coils. There may still be a small amount of coolingbecause the coils are icy, but with no air flow over the coils, coolingin the refrigerator compartment is quite limited.
Here's aninexpensive, though inconvenient, way to determine if the problem iswith the self-defrosting system. Remove all of the perishable food fromthe refrigerator and freezer, turn the thermostat in the refrigeratorto Off, and leave the doors open for 24 to 48 hours. (Be sure to haveseveral towels ready in case the melting frost and ice causes the drippan to overflow). This allows the refrigerator to defrost "manually."When the frost and ice build-up has completely melted away, turn thethermostat back to a normal setting. If the refrigerator then coolsproperly, it indicates a problem with one of three components in theself-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
Ifit still does not cool properly, there may be a problem with therefrigerant level or the compressor. You may need to consult with aqualified appliance repair technician to further diagnose the problem
Condenser Self-defrostingrefrigerators all have a set of coils and a cooling fan, usually underthe refrigerator, that need to be cleaned regularly. If these coils getcoated with dust, dirt or lint, the refrigerator may not cool properly.The coils may appear to be a thin, black, wide radiator-like devicebehind the lower kick-panel. To clean them, disconnect the refrigeratorfrom the power source, use a refrigerator condenser brush (see theAppliance Accessories section) and your vacuum cleaner to clean thecoils of any lint, pet hair, etc. You may not be able to get to all ofthe condenser from the front, it may be necessary to clean theremainder of the condenser from the rear of the refrigerator.
For more troubleshooting tips, please visit this site:
http://www.repairclinic.com/0088_4_1.asp#Level1_3
Hope that helps!
If your issue isnot resolved, please do not assign a rating just yet. Please post back asto what steps you took, results, etc, and I will try to assist you further asbest I can.
P.S. - You can rate asolution with one of four ratings as explained under (remember that at times abit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Why is my whirlpool wrn28nwb6 not freezing?
Check your defrost timer also make sure its turning also there's a thermostat and heating element that defrost the ice at given cycles
May 16, 2014 | Freezers
Frigidaire 18.2 cuft top freezer refridgerator either melts or freezes everything
The defroster heating elements are burnt out and won't defrost and causes system to freeze up. Then it won't cool. Unplug ice will melt off cooling fins then it will cool till it freezes up again. Install new defrost heating element. Replace both.
Jan 15, 2014 | EuroCave Performance 283 Wine Cellar
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
The refridgerator is not cooloing and the freezer is beginning to frost up
This sound if the blower motor in the freezer section is not working, everything freezes and the bottom does not cool, you will need to remove the cover in the back of the freezer and if the fan is not working it will need to be replaced
Oct 30, 2009 | Refrigerators
Whirlpool Side by Side: Freezer freezes refrig doesn't cool.
check for a blockage. There is only one cooling section, divided by airflow for freezer / fridge.
Perhaps something sticky is in the vents, or the freezer section has poor airflow, resulting in ice formation.
Unplug the unit for several hours, clean out vents, and make sure freezer section has good airflow from the vents.
Aug 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Evaporator freezing up on my ge gss25tsrd refridgerator
YOU CAN SEE HEAVY FROST ON THE REAR OF FREEZER WALL?
Jan 29, 2009 | GE Refrigerators
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refrigerators Logo
213 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
