Question about Miele XLWDSTAND Washer and Dryer Stand
Separate miele washing machine and dryer
I have a miele washing machine with a dryer connected on top. Can anyone tell how to separate the 2 machines?
  • jenddy Sep 30, 2008
    Thanks. Very helpful and problem solved.
  • 1,122 Answers
If you go to sears .com click on parts put your model number in(should be inside dryer door)it willl break down and show you everything you need to know,let me know how it turns out,mike
Posted on Sep 28, 2008
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Miele washing machine starts up then goes off I have to wait hour or two press it on it starts then stops again can you tell me what's wrong thank you
You do not mention the model number of your machine.
This happens more often with Miele washing machines with an EL150 electronic.
If so, it can be found below the top cover.
From this electronic it is known that the resin in which the transformer is cast, is developing small cracks. These cracks tear the thin copper wire of the primary winding apart. If the temperature drops, the cracks close again. Remedy: replace electronic or have it fixed (google on "Miele EL150 defective").
Mar 11, 2015 | Miele Washing Machines
Can I separate the pair and just use the dryer?
I wouldn't know as you are asking this question in vacuum section
Jan 26, 2014 | Whirlpool LTE5243D Top Load Stacked...
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
Jan 08, 2014 | Miele W1926A Front Load Washer
How to put top back on miele w1926
1 Remove stacking kit from top of unit.
2 Reatach the two plastic clips to the back of washer.
3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
Dec 29, 2013 | Miele W1926A Front Load Washer
How to change the heating element on miele wt945
take the back off the heater has 1 10m nut in the middle and 2 wires on it take off wires undo 10m nut prize off the heater it is compressed in a rubber it might take a bit of force the best thing to do before this is to test the heater with a multi meter 1st if there is no reading across the two terminals the heater has gone get a new heater and have a look at it you will see what holds it in
Sep 26, 2012 | Miele WT945 Front Load Washer / Dryer
Miele novotronic wt 945 door release button not responding wash functions not responding when turned on and off only drier light is on no actual response from drier section cannot open the machine Is this...
Open the door manually.
Open the drain flap on front left bottom
The door release can be seen hanging, pull the cord, the door will open.
Close and open the door 2 or 3 times and your machine will work ok.
S. Datta
Mar 06, 2011 | Miele WT945 Front Load Washer / Dryer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
275 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
